Technosat T-888 connection problem
Old 12-03-2006   #1
My System: Accessing NSS6 satellite Having P4 2.8GHz computer
Exclamation Technosat T-888 connection problem
I tried to connect my Technosat T-888 receiver to my PC using STBLink7 software via the RS232 cable. But it always try for few secs with the message progressing & then gives connection failed message. How to correct this & get the correct connection?
When I'm connecting, do I have to do anything on the receiver too other than connecting the RS232 cable to it?
Please help.
kav4 is offline   Reply With Quote
Old 12-03-2006   #2
My System: HISPAST
Please help.
i have t888 and i use may cabel and is not problem mour is not ani pc, and were you finis use de number 8088
Agrela3 is offline   Reply With Quote
Old 13-03-2006   #3
yes I have used the number 8088 to reset the receiver. But it not connect with the pc using STBLink7 or STBLink5 softwares.
Please help
Old 24-06-2008   #4
My System: Satellite
how to reboot t888plus?
can i use this t888plus here in the phillippines? pls help me... i allready install the dish and it always in scramble chanel,. what should i do? is there any codes or software i can use? i need your expertise... THANKYOU
waxxx_ctf is offline   Reply With Quote
connection, problem, t888, technosat
[IMG] code is Off
Similar Threads
Technosat IR-7000 Upgrade akshariff Receiver software, international Section 16 18-04-2006 01:34 PM
Magic Module connection problems naffats Magic Module 8 01-04-2004 02:54 PM
Have a problem with Vision Plus mgharbawy Satellite PC Card Receivers & Internet by Satellite 1 15-02-2004 10:47 PM
Sky Active Connection Problem Colinsav Sky Digital (BSkyB) and Astra 28.2 East General 0 16-12-2003 03:36 PM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
