Silvercrest SL 65 Receiver
Information exchange on digital satellite systems other than Sky
Old 29-08-2006   #26
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
Originally Posted by JAMBOliam View Post
does it mean i could recieve all of these at once?
No it would just help with the weaker signals.
Do you have a picture of the tree and how far away it is. The dish is almost vertical but the signal is received by the LNB which is at an angle. if you can imagine the opposite angle and that clears the tree then you're OK.
see here... http://www.satellites.co.uk/php-bin/...8&d=1117750003
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 29-08-2006   #27
My System: Silvercrest SL65 with DiSeq 1.2 motor, HDrive 100gigs, dvd recorder, 5.1 goodmans surround sound, xbox360 wifi live,goodmans GD3
dont think the tree will be a problem, its to the south of the satellites im picking up.
just built a pole to place my satellite on top of, so will test it all out tommorow, fingers crossed!
JAMBOliam is offline   Reply With Quote
Old 30-08-2006   #28
Ding Dang Doo
gameboy's Avatar
Would need to be a long pole -
I take it you refer to the dish?
Old 30-08-2006   #29
harrowwoman's Avatar
My System: Silvercrest SL65 FTA receiver + two dish setups. One 90cm. one 60cm two universal LNB's.
Unhappy Silvercrest SL 65
I went ti Lidl on Monday also, and purchased the Silvercrest to replace my Echostar which I find difficult to programme.
I set it up without any problems scanned for Hotbird, got all the FTA channels on that. I have two dishes, one 90cm pointed at Arabsat, one smaller pointed at Hotbird (or it my be the other way around, cant remember now), two universal LNB's.
Now, in the pre-programmed satellite list I couldn't find Arabsat. How would I be able to scan for that, and what other satellites would I be able to get with these two dishes and the direction the are pointing? Should I set up the Echostar to just get the Arabsat and leave the Silvercrest one to do Hotbird? I also bought a thingy for searching the satellite signals, where would I insert this? I also got another LNB (just in case), can I add this to the dish somehow to pick up other satellites?
harrowwoman is offline   Reply With Quote
Old 30-08-2006   #30
Amo Amas Amant Admin
Topper's Avatar
Well
If this was working before with the Echostar then do we assume you have a diseqc switch? Or were you manually changing cables?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 30-08-2006   #31
Ding Dang Doo
gameboy's Avatar
It comes with a short lead, attach one end (doesn't matter which) to the LNB at the dish. The other end to the Satellite Finder, if you check the back of the finder each side is marked LNB or Receiver.
The cable end that you will connect to the LNB from the receiver goes into the receiver port on the satellite finder. If you turn up the volume - when you find a satellite position is will scream (loud) then adjust the volume to the weakest signal and adjust the dish to see if the signal improves. Keep adjusting to get the best signal then tighten the dish and remove the finder.
You can only use this if your receiver has two LNB inputs otherwise you will need a switch or two receivers.
Old 30-08-2006   #32
i just managed to find hotbird, got Mediaset, and all the RAI, and also managed to keep some of my favourites from astra, RTL and Super RTL, guess they are on hotbird too, along with tonnes of arab channels, very happy indeed
however, was watichin Raiuno and when a programme i wanted to watch came on, the screen came up with the 'scrambled' message, it had happened before with raitre, but i thought it might just have been interference on the signal, but happening twice got me a bit worried.
do certain channels scramble their signals for satellite viewers for some programmes? or was it just a glitch?
Old 30-08-2006   #33
rolfw's Avatar
Real name: Rolf
It is standard, they will be programmes for which they only have Italian copyright.
Rolf
Old 30-08-2006   #34
Hi
Yesterday I had a SilverCrest SL 65
I think it is brilliant for the money
I understand you can enhance the
performance of the receiver by patching
the software .
have you any views on this,
what links I've found are all dead
Jamie
Jamie is offline   Reply With Quote
Old 30-08-2006   #35
Topper's Avatar
Well
Hi Jamie
No the SL65 cannot be patched AFAIK
Show Your Support
Thank you.
Old 31-08-2006   #36
My System: silvercrest sl65
Hi I have just brought a Silvercrest SL65 and was wondering if i can receive all freeview channels you get off a freeview box and is the quality better than analouge. Also will i receive digital quality signals if so
Thanks Stanners91
stanners91 is offline   Reply With Quote
Old 31-08-2006   #37
Topper's Avatar
hello
Welcome to the forum stanners91
You seem a trifle confused here. Freeview is the terrestrial digital transmission which is currently transmitted simultaneously with the terrestrial analogue channels until the latter is switched off.
The signal you receive on the sl65 will be digital and better quality than the analogue signals but not necessarily better than the digital terrestrial.
No you cannot currently receive channel4 and channel five as they are nds encrypted until 2008 but they can be received using a £20.00 sky card no subscription necessary
Show Your Support
Thank you.
Old 31-08-2006   #38
Thanks Topper,
I assume there is a diseqc switch as I did not have to touch the cables.
Last night I sat there for about three hours trying to figure everything out. As I have just bought the receiver should I do an upgrade yet? Would that improve anything?
I did manage to work out how to get Nilesat (or think I have) I just went to New Satelite, changed the name to Nilesat and did a scan....it seems to have picked up loads of channels, but whether they are actually Nilesat I dont know till I get home with my copy of What Satellie bought this morning on the way to work.
Has Arabsat changed its name to Badr?
My son-in-law has the same receiver bought some months back, that seems to have a different set-up procedure which is easier than this one.
I would really appreciate it if you could tell me if I am doing it wrong?
Old 31-08-2006   #39
rolfw's Avatar
Real name: Rolf
Locate Arabsat in the satellite setup panel of the menu and allocate it to DiseqC 2 of 2, you should then be able to scan it for channels.
Rolf
Old 01-09-2006   #40
mick2me's Avatar
My System: 'Fortec Star Passion' (& a dead SL65) One of them big Woks on the outside, and a thingy that moves it about a bit.
I've been away from these forums for a while.
Is there a working patch for the 65 yet?
The best way to learn is from your mistakes... Sorry I made a mistake!... The best way to learn is from others mistakes.
_www.Nottstalgia.com
The Nottingham Forums
mick2me is offline   Reply With Quote
Old 02-09-2006   #41
rolfw's Avatar
Real name: Rolf
There is a long thread in the Portuguese "Other Receivers" section, I believe that it requiresa JTAG to install or modify the bootloader first. But it is definitely patchable to some degree.
Rolf
Old 03-09-2006   #42
My System: silvercrest digital satellite system 60cm dish receiver dvb-s sl65 and universal twin lnb brought from Lidl
A little help from anyone please!
I too have a Silvercrest system,can pick up most channals but i am looking to pick up romanian tv for my wife. I have read the channals are broadcast on the sirius satellite,is it just a matter of a lot of playing about with it to get it to pick up the satellite? I am also thinking of a motor for the dish,so would the dish align its self automatically(the motor would be of course DISQC compatible to the receiver) sorry for going on a bit,but any help would be great,thanks for your time.Lee. oh and from my wife. Also not sure if i am posting this in the right place,sorry.
lee mckean is offline   Reply With Quote
Old 03-09-2006   #43
Site administrator
Analoguesat's Avatar
Yes the Arabsats have been redesignated to Badr.
You can find more uptodate info on various frequency sites. This one is excellent and easy to understand
http://www.flysat.com/satlist.php
Analogue forever!
Old 05-09-2006   #44
My System: Comag 2CI
Cool
Warning to all - the Silvercrest SL-65 recently sold by Lidl in the UK is based around a different (Ali) chip from the previously sold model of the same name. Before anybody gets excited with discussions elsewhere as to what's possible in temrs of flashing new firmware onto an SL65 STB - be aware - if you've just bought a new one from Lidl - they are probably talking about a different STB. At the moment, there appears to be no software patch for the "new" SL65.
nïë1o
nielo is offline   Reply With Quote
Old 05-09-2006   #45
Site administrator
Jamboliam. Im only 30 miles south of you. Have a look at my digitalsat website
_http://www.digitalsat.co.uk
You should get similar results with your dish. You wont get everything as Im using 80cm dishes, but it will give you a representative sample of the stronger satellites you can expect to find.
Analogue forever!
Old 06-09-2006   #46
My System: DVB-S SL 65
I just got the silvercrest system from LIDL, with an 80 cm dish. Anyway I dont know much about satellites. I installed it ok and am getting italian and german stations and loads of arab stations aswell.
What I want to view though are the English Channels BBC, ITV etc which I am not recieving due to a poor signal. I tried moving the dish a bit, but it didnt work. Would it help if I installed another similar dish in the opposite direction?
Thanks.
Angie 76 is offline   Reply With Quote
Old 06-09-2006   #47
Ding Dang Doo
gameboy's Avatar
Sounds like you're no pointing at 28 East - where the UK channels live.
Maybe 19.2 East Astra or 13 East Hotbird.
Check the other Sky dishes in your area and that will give you an idea where to point the dish. It will be to the left of your current position when viewed from the back of the dish.
Mark the dish position on the mount before you move it - then you can put it back easily.
Old 06-09-2006   #48
Thanks for the info.
Old 06-09-2006   #49
spiney's Avatar
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
To find Sky, (in UK!), should also work in Eire ......
1 The big 3 (largest output power, so cause biggest "noise" on a sat-finder) European dbs sats are Hotbird, Astra1, Astra2 (Sky)).
2. Of these, Hotbird is furthest right (looking from behind dish, towards satellite).
3. Astra1 is then approx 3 degrees left of Hotbird.
4. Asta2 (Sky) is then 9 degrees further left of Astra1, so that's 3 times the previous separation, and also DOWN JUST A LITTLE BIT!
I can't comment on relative beam strengths as received in EIre, you'll have to look at "footprint" maps, easy enough to find on Web!
spiney is offline   Reply With Quote
Old 06-09-2006   #50
My Freeview box is playing up (has been since the first day I set it up), its a Thompson with a slot for Top Up TV. I am going to take it back and get a refund. I was looking through the posts here and can see that some channels should be available on my satellite (so why buy another Freeview) would I be able to get the normal five, plus some of the sky channels without a Sky card if I move one of my dishes?Hmmm?
receiver, silvercrest
[IMG] code is Off
Similar Threads
2 dishes: Add 2nd receiver, UHF TV and FM Artist 2004 Multi-receiver/TV systems - Domestic only 8 11-03-2007 09:14 PM
Samsung dead. PLZ HELP!!! Zebo Receiver software, international Section 9 16-02-2006 12:05 AM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
receiver query Eutelsat Hotbird dcjag Digital systems 3 03-10-2003 03:48 PM
IFA 2003 Berlin exhibition report net1 Digital systems 0 01-10-2003 08:02 PM
