Silvercrest SL 65 ReceiverInformation exchange on digital satellite systems other than Sky | |
| | #51 | ||
| Guest Join Date: 29-04-2005 Location: Midlands
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | ops, sorry harrowman, pressed wrong button, though no doubt you don't mind! (my fault, this time, can't blame faulty dns or browser....). Free Sky channels exclude ch4/5 ( a £20 freesat card gets those, but on a sky digibox only!), and e4/more4. Also, you don't get tmf or ftn (just in case anyone actually watches them!). Otherwise, for the rest, see the free Sky channels list on Lyngsat website. | ||
| | #52 | ||
| Member Join Date: 05-09-2006 Location: Republic of Ireland
My System: DVB-S SL 65 | I finally managed to get all the English channels by moving the satellite in the right direction, although I lost all the Italian channels by doing this, dont really mind though. Thanks for the tips | ||
| | #53 | |||
| Member Join Date: 25-08-2006 Location: Edinburgh
My System: Silvercrest SL65 with DiSeq 1.2 motor, HDrive 100gigs, dvd recorder, 5.1 goodmans surround sound, xbox360 wifi live,goodmans GD3 |
| | #54 | ||
| Member Join Date: 02-03-2007 Location: Cheshire UK
My System: Silvercrest SL65 |
I have been using the SL65 for a while, but two problems occur: 1) I cannot seem to get a signal from RTBF SAT,or am able to edit the channel. 2) Stop the dish losing its position when it is windy and blows out of position. Do I get a motor, if so which one is recommended. I have been on Hotbird but now have it pointed to Astra 19.2. Anyone offer help here? | ||
| | #56 | ||
| Member Join Date: 20-07-2007 Location: north wales
My System: silvercrest sl 65/12 dvbs | purchased a silvercrest sl 65/12 dvbs reciever,complete with everything,got it for using with tourer caravan,it all slots together and is great,but...cannot get channel 4....or..channel 5.it says scrambled?can anyone help?as to when it will be unscrambled,email me please..mikeandjude59@msn.com | ||
| | #57 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | Don't post your email address unless you want endless spam mail... | |||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | ||||
| | #58 | |||
| Member Join Date: 26-08-2007 Location: Inverness
My System: Lidl silvercrest |
When connected to the receiver I get between 60-80% signal intensity however the signal quality sits at 14%. From the above quote I assume that the azemuth angle changes but the vertical orientation doesn't? Can the lidl kit cope with this latitude? Am I just too far north? Thankyou all for the info it's helped allot. | |||
| | #59 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | ![]() Astra 2D doesnt have a north beam. All the 28E satellites are co-located so if you can see one you can see all of them | ||
| | #60 | ||
| Member Join Date: 28-08-2007 Location: Kent
My System: SilverCrest SL65 (Trying to get it to work) |
Just brought the Silvercrest SL65 Satellite kit. Using other sky minidish's in the area as a guide. Set the dish in roughly the right direction and angle. As I want to recieve Astra1 28.2E. Then using the sat-beeper that came with the kit moved the dish to the right location according to the highest pitched sound coming from the finder. Which meant I need to move the dish to a slightly different position. (The sat-beeper only seems to change pitch in 1 place, expected serveral changes at each satellite location) But nothing....now I'm new to all of this and the instruction manual does't help. TV shows a no signal message, with a raindrop type of symbol. I did manage to get the screen on the TV to show between 60-80% signal intensity and the signal quality at 14%, when I go to antenna setup. According to the troubleshooting part of the manual 60% should be good enough but still no pictures. Please any help.....thanks jay | ||
| | #61 | |||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | | |||
| | #62 | ||
My System: SilverCrest SL65 (Trying to get it to work) | Topper Thanks for your thoughts.....I've started another thread on this one Silvercrest SL65 Install Problems (Astra2 28.8E) But here is a copy of my reply Good and bad news I'm afraid to say. ![]() I adjusted everything to the right positions...LNB skew to 25 minutes to the hour from behind the dish...elevation was out so using the guide on the rear of the dish now set to 25 degrees...the azimuth (direction) 146 degrees actually slightly more as using magnetic north. Then ensured Astra 28.2E was selected in the set up and checked that the TP frequency was set to 10714 which it was. Used a Satfinder to double check and it showed a strong signal. Then performed an Auto Scan and found loads of channels.... Turk Shop Turk Spor Turk TV Ordu TV Hayat TV Istanbul TV Hilal TV........ so I assume that’s Turksat 42E found then ha ha. (But as I’m new to this I may be wrong, but have written down the whole list of channels) After finding these channels I did do a further check in the Antenna Set Up Menu to ensure I was still on Astra 28.2E and 10714 and it was. So the big question....where is the holy grail Astra 28.2E from here??? I marked this position on the mounting pole, and leaving the skew and elevation as it was. I've tried moving the dish left to right (viewing from behind the dish). The Satfinder has found two more strong signals one each side of my mark, about 5mm either side. I did retry an Auto Scan at both locations but nothing, and no pictures. Apologies for going on a bit here, but just want to give as much info as possible. Any ideas, thoughts or instructions, to get Astra 28.8E gladly received Thanks again | ||
| | #63 | ||
| Member Join Date: 29-08-2007 Location: Midlands
My System: SilverCrest SL65 | Joining this thread in the hope someone can help. Just bought a SL65 from Lidl but when I set it up I got “no signal”. I got a reading of 82% intensity but only 14% quality. Moved the equipment to a friends who bought one at the same time, his works fine, mine no joy. I exchanged the unit. The second one is the same. Is it me or is it back to Lidl Thanks | ||
| | #64 | ||
| Mentally unstable. Join Date: 27-03-2005 Location: S. Yorks
My System: Pretend to know what I'm doing. Only the clever ones rumble me. ![]() ...Now he's joined a sat forum, And boy does he borem, When the hind legs off a donkey - he talks | Hello BryanF, If you look at this thread you may get some idea of what to try. Silvercrest SL65 Install Problems (Astra1 28.8E) But first of all make sure that your F connectors are correctly fitted. If you are getting no fluctuation on your signal it could be a poor connection to either Lnb or receiver. This shows you how to make a good connection. _http://www.satcure.co.uk/tech/fconn.htm Yorks. | ||
| Life's a bitch ................ and then there's S*y (No change there then) Wurdoch ist ein Manker. (Mank being a city in the Austrian Alpine foreland) ![]() Last edited by Yorks; 30-08-2007 at 09:53 AM. | |||
| | #66 | ||
| Member Join Date: 02-09-2007 Location: Hertfordshire - AL87JW
My System: Silvercrest-Comag SL65 | I too got a SilverCrest SL65 satellite receiver from Lydl and it works perfectly, but... for everything except UK FreeView. Signal strength and quality on Astra 28.2E is good, same as default Astra 19.2E, which seems to be so close in the sky that I don't need to reset the dish. I get lots of channel on 28.2 but except BBC World, none of the big 5. BBC, ITV etc. I've tried re-scanning but that doesn't help. What am I doing wrong? Anyone else got the same trouble? Mark | ||
| | #67 | ||
My System: Pretend to know what I'm doing. Only the clever ones rumble me. ![]() ...Now he's joined a sat forum, And boy does he borem, When the hind legs off a donkey - he talks | If you are getting BBC World then you are not pointing at 28E. BBC World does not broadcast on 28E If you are pointing at 19.2E then you will not receive any channels from 28E without moving your dish. Although you may get a signal, this is only because some of the channels on different satellites share similar frequencies. Yorks. | ||
| Life's a bitch ................ and then there's S*y (No change there then) Wurdoch ist ein Manker. (Mank being a city in the Austrian Alpine foreland) ![]() | |||
| | #68 | |||
My System: Pretend to know what I'm doing. Only the clever ones rumble me. ![]() ...Now he's joined a sat forum, And boy does he borem, When the hind legs off a donkey - he talks | Yorks | |||
| Life's a bitch ................ and then there's S*y (No change there then) Wurdoch ist ein Manker. (Mank being a city in the Austrian Alpine foreland) ![]() | ||||
| | #69 | |||
My System: Silvercrest-Comag SL65 | ![]() Embarrased, I should say so, and I did broadcast television at the end of the 50s when we could just about attain 45MHz (sorry 45,000,000 c/s) and get a reasonably stable horizonatal flyback with 405 lines. Now.. Arthur Clark has a lot to answer for. The point is, it doesn't help to live in a wood. On my fifth attempt, with the dish clamped to a step-ladder, I found a gap in the trees and Astra 28.2E. And the BBC1 - don't know what else as it began to rain and I had to rush a borrowed portable TV and the satellite receiver into the house. Anyhow, thanks York and the rest of you guys for putting me right. If you want to see what a handycam looked like in 1958, take a look here at me half a century ago. http://panoradiant.co.uk/oddsods/oddsset.htm It's the last item in the list Mark http://panoradiant.co.uk | |||
| | #70 | ||
| Member Join Date: 09-10-2007 Location: ROMFORD/ ESSEX
My System: SILVERCREST SL65 |
i am just surprised when all of you guys saying that you are getting them channels, all i get from it just all the itv, bbcs and a total of 20 boring channels, cannot get no channels from outside of the uk like the rai, german or italian or french. few of them there is no signal, some of them the signals are above 60% but still cannot get them it just dark, the screen, i moved my dish all over but still cannot get any german or italian, or french channels. i live in essex and iam using the lidl dish. anyone can help me please | ||
| | #71 | |||
http://www.satellites.co.uk/satellit...lite-dish.html | |||
| | #72 | ||
| Specialist Contributor Join Date: 16-01-2005 Location: Lancashire
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought. | Does anyone have a patch and instructions on how to do it for the 65 of 32 years ago ? | ||
| | #73 | ||
| Member Join Date: 03-05-2004
| | #74 | ||
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought. | Mine is the 1st sl65 aldi sold I patched it ages ago for tps but thats long finished how would I know if its the b1? | ||
| | #75 | ||
| Member Join Date: 11-08-2008 Location: Portugal
My System: sl 65 | Hi everyone! I just bought a SL 65 Silvercrest from Lidl in PORTUGAL too. I get 70-80% of signal intensity but the signal quality stays at 14% . I move slowly the LNB I tried everything (I think...) but it remains the same. I'm new to the subject. Why it doesn't change ? I apreciate any help tks amg | ||
| receiver, silvercrest |
Similar Threads | ||||
| 2 dishes: Add 2nd receiver, UHF TV and FM | Artist 2004 | Multi-receiver/TV systems - Domestic only | 8 | 11-03-2007 09:14 PM |
| Samsung dead. PLZ HELP!!! | Zebo | Receiver software, international Section | 9 | 16-02-2006 12:05 AM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| receiver query Eutelsat Hotbird | dcjag | Digital systems | 3 | 03-10-2003 03:48 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
