Comag FTA ReceiverInformation exchange on digital satellite systems other than Sky | |
| | #26 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | They should come in fine with a 60cm, check that you have the correct symbol rate and FEC settings 27500 and 3/4 respectively, plus check that you have 22Khz tone switching at on or auto and that you have a universal LNB. | ||
| | #27 | ||
| Regular Member Join Date: 04-08-2003
My System: DM7020Si+40GB, Comag FTA 2CI(Conax Cam + Card), SG2100 DiSEqC H-H, Triax 88cm, Invacom 0.3db - 28E to 30W. | This sounds good. It must be my lnb then, it was installed by sky before 1996 and they didnt use universal lnb then. thanks rolfw i'm just off to get one.. | ||
| | #28 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | LOL, up the ladder again then Rai. | ||
| | #29 | ||
My System: DM7020Si+40GB, Comag FTA 2CI(Conax Cam + Card), SG2100 DiSEqC H-H, Triax 88cm, Invacom 0.3db - 28E to 30W. | Since I'm going to buy a new LNB, would it also be possible to get hotbird with a monobloc lnb (as somebody suggested on this thread) on a 60cm here in manchester? or am i asking too much? just a thought.. need to borrow the neighbors ladder though, hope he dont ask for a dual output lnb. :-p | ||
| | #30 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You'd be pushing it with a 60cm, an 80cm would be preferable, but as you'll be likely to pay £50 plus for a monobloc, it would probably be better to wait until you get a motor to consider Hotbird. | ||
| | #31 | |||
| Guest
Posts: n/a
| | #32 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The 45cm minidish does not perform far behind a 60cm dish, you may still get some drop out on hotbird in bad weather though. If you offset one or both LNBs on a 60cm, something is going to suffer. | ||
| | #33 | |||
| Guest
Posts: n/a
| | #34 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The symbol rates are very low on some of the 16E channels, your receiver may not handle them, check it out and see, MTV Italy has a symbol rate of 6111. | ||
| | #35 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | | ||
| | #36 | ||
My System: DM7020Si+40GB, Comag FTA 2CI(Conax Cam + Card), SG2100 DiSEqC H-H, Triax 88cm, Invacom 0.3db - 28E to 30W. | interesting. just a quick update rolfw. replaced my lnb with an universal one - top banana! got all the FTAs. Now waiting for my paypal to work properly, for some reason CC payment is declined every time I try to buy a MR from toecutters.. appears to be a problem on paypal site. will try tomorrow again. Rai | ||
| | #37 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You can always transfer the money direct from account to account Rai, the details are in his signature | ||
| | #38 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | OK, Auction over for the Comag and MR, didn't reach reserve, doesn't surprise me, even though it was potentially good value, nobody wants to buy from a guy with only one previous transaction, reselling widely available goods.
| | #39 | ||
My System: DM7020Si+40GB, Comag FTA 2CI(Conax Cam + Card), SG2100 DiSEqC H-H, Triax 88cm, Invacom 0.3db - 28E to 30W. | Been doing lot of reading in Den in me spare time, learning some technical side of things. the order for MR is on hold until I have a motorised dish to take full advantage of MR. any chance of Seca2 being hacked? :-) | ||
| | #40 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Don't know, is the simple answer to that Rai. | ||
| | #42 | ||
| Regular Member Join Date: 01-01-2000 Location: Manchester
| Hey Rai, if you're in Manchester I can reccomend a sound guy to carry out any sat related work for you, very reasonable and top quality, I've been buying off him for years, pm me if you're interested! | ||
| Don't play silly buggers with me because I always win! | |||
| | #43 | ||
My System: DM7020Si+40GB, Comag FTA 2CI(Conax Cam + Card), SG2100 DiSEqC H-H, Triax 88cm, Invacom 0.3db - 28E to 30W. | thanks digimac, it'd be nice to have good local contacts. please do pm me with the details. does he also sell satellite equipments? I'm in favour of paying top money for top quality job (it works out cheaper in the long run) but first i'd be interested in the technical do-das meself (to save money in the long run). Rai | ||
| | #44 | |||
| Regular Member Join Date: 27-08-2003 Location: UK
a good quality monobloc is only 32 Euros ..( about £22 ) in Spain... I know....I know..I'll get my coat.. An update on the Comag, I managed to upgrade the software to 4.23 .. Bootloader 8 today, links at the Unnofficial Comag Site. WOW, what a difference, it flys now. and channels open almost instantly with the Matrix R, oh and it seems to load channels faster. Its getting better all the time. 70 quid...with a 3 year warranty and 2 CI slots...Humax...Echostar...eat yer heart out.. Such a lovely " Lidl " box of tricks.. silvernet | |||
| | #45 | ||
My System: DM7020Si+40GB, Comag FTA 2CI(Conax Cam + Card), SG2100 DiSEqC H-H, Triax 88cm, Invacom 0.3db - 28E to 30W. | yeah I've upgraded to version 4.23 as well, wouldnt know the performance increase as it is my first FTA receiver but it looks sound. Would be interested to know if anyone had tried powering their motor with its diseq1.2 (as it says on the tin). | ||
| | #46 | ||
| Irish Mod Join Date: 30-09-2002 Location: Ireland
| You sound like one happy man, Rai. Let me know how you get on with the motor. Hope to go down that road myself, if I can somewhere in this backward land that sells large dishes and motors. | ||
| Don't mind my spelling | |||
| | #47 | ||
My System: DM7020Si+40GB, Comag FTA 2CI(Conax Cam + Card), SG2100 DiSEqC H-H, Triax 88cm, Invacom 0.3db - 28E to 30W. | Anything to keep this thread alive mate. :-p You will all know when I get my motor, it will be a noisy one I can assure you. | ||
| | #48 | ||
| Member Join Date: 20-04-2004
Software upgrade for COMAG FTA Satellite receivers can be downlaoded from the official website in Germany. www.coag-ag.de | ||
| | #49 | ||
| | #50 | |||
| Member Join Date: 24-04-2004
Thanks. | |||
| comag, fta, receiver |
Similar Threads | ||||
| Eutelsat satellite WC full channel coverage list | Analoguesat | Jimbo's Football and Sport | 0 | 07-06-2006 11:27 PM |
| Transponder update 27/09/03 (Part 1) | Satdude | Transponders & channels | 1 | 27-09-2003 09:03 PM |
| Transponder update 20/09/03 | Satdude | Transponders & channels | 0 | 20-09-2003 09:26 PM |
| BBCinteractive wiht simple FTA receiver | bachopin | Sky Digital (BSkyB) and Astra 28.2 East General | 3 | 28-07-2003 12:25 PM |
