Help in replacing setup
Information exchange on digital satellite systems other than Sky
Old 09-08-2006   #1
malcolm's Avatar
My System: Sky+ (basic sub) Echostar AD3000IP Dragon Cam Infinity Phoenix Geotrack polar mount 88cm Triax dish Digitalb Supersport
I'm going to renew my dish/lnb and motor (original rusted sly anologue 70cm dish, universal lnb and hh motor with reliability problems) and have picked out the following items (on a low budget) -
MTI AP-ST2BL LNB £6
Geotrack polar mount £35
80cm Televes offset dish £27
I would like to know if they are all compatible? or should I be looking for a larger dish?
Malcolm
malcolm is offline   Reply With Quote
Old 09-08-2006   #2
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
You might consider a Triax TD88 dish instead, depends on what you plan to recieve. Otherwise fine mate.
L.
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 09-08-2006   #3
malcolm's Avatar
I have an Art card for Hotbird and would watch the footy on Hispasat if it's still available?
Cheers
Old 09-08-2006   #4
Lancelot's Avatar
D+ and Cabo down at the moment.
L.
Old 09-08-2006   #5
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
also why not go for a 90cm gibertini dish nice and light made from aluminum
Old 16-08-2006   #6
malcolm's Avatar
Changed to the Triax TD88 dish, all arrived today, now just have to find time to assemble them and get up that ladder!
Thanks for the posts
Malcolm
Old 16-08-2006   #7
Lancelot's Avatar
Good choice
It'll be a stunner compared to your old 70cm.
Keep us posted....
L.
Old 17-08-2006   #8
wod
wod's Avatar
Malcolm
hi, there where'd you buy the dish from ?
replacing, setup
[IMG] code is Off
