Digital CableInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 26-08-2006 Location: Essex
My System: Sky digibox |
Can any body help me i have been left a lenth of this two core cable title Digital Broadband which has a thick cable a nd a thin cable can i use the thick cable as a coaxl cable for a superior tv cable as it is probably shielded if so do i need to purchase a different coaxl cable connector than the normal bog standard The cable simulates a figure of 8 and is black in colour Many thanks | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | If the smaller cable is a telepone cable, it is probably cable TV product, so will be fine for TV distribution, the connectors required will depend on the cable diameter. | ||
| Guest Join Date: 29-04-2005 Location: Midlands
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | Cable tv - analogue or digital - uses frequencies only as far up as lower UHF, any coaxial cable at all should cope with that. It will be 75 Ohm, hence either rca or f connectors can be used, interchangably. If thicker coax, it's probably CT165 (equivalent) for distribution as far as the junction boxes, yes you'd need special plugs for that. For thinner ct125, you can "bodge fit" a standard ct100 coax, just screw down over the stripped outer braid, don't try it over the outer insulation! | ||
| cable, digital |
