LNB Cable Dish from Lidl
Information exchange on digital satellite systems other than Sky
Old 09-09-2006   #1
My System: SL65 Astra 28 Astra 19
Hi Guys
new to thsi board nice place....
ok i bought a Lidl dish the silvercrest few weeks ago
ive put the dish on the roof
however i read in the book that u need an LNB cable and its not supplied orsomething like that
does thsi mean i need one or something
cos what i did was fix the long white aerial (co-axial) with fconnector from LNB direct to receiver
is this right?
sorry im a sattelite dish idiot!
whoimi is offline   Reply With Quote
Old 09-09-2006   #2
My System: Technomate1500ci super with 78cm dish fixed on Hotbird
The signal you are trying to pick up is so small that it can be completely lost using the wrong type of cable. You need the correct cable (CT100) or equivalent with no joins along it's length, and as short as possible, but no sharp bends.
UPS1950 is offline   Reply With Quote
Old 09-09-2006   #3
rolfw's Avatar
Real name: Rolf
If you are receiving the channels you aimed for, then you don't need to change anything, but we did test the cable which was supplied with the dish kits and it was not reall suitable for the purpose, losing 20% of the signal over the 12/15m length.
WF100 or CT100 would achieve far superior results.
Rolf
Old 09-09-2006   #4
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
Check the cable you have if it has a foil shield between the core and the outer copper wire it's satellite cable.
If it doesn't replace it...
LNB Cable Dish from Lidl-ht051_2-jpg
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 09-09-2006   #5
rolfw's Avatar
Real name: Rolf
If the OP has used the RG59 suppied by Lidl, then it is double screened GB, but it is still very high loss.
Rolf
Old 09-09-2006   #6
Hello You lovely people
Thanks for the reply
yeh its an RG59 Cable I just had a look at it..So its not really suitable then eh?
Will i need just a cable like WF100 or CT100 and all i do is connect it to the LNB and to the Receiver and thats al?
is that right?
does anyone know where to get these cables i tried Argos,dixons etc no one sells it
Old 09-09-2006   #7
My System: Sky+HD Astra+Hotbird FTA on 60 cm dish
screwfix direct online sell all types of coax and have Philex FT100 cable at about £40 for a 100mtr coil, They also sell normal satellite coax with the foil inside for about half that which is the cable i use. Worth getting a whole drum off the cable and using it for TV downleads as its really good quality stuff.
is that right?
streetlighter is offline   Reply With Quote
Old 09-09-2006   #8
Ahh i found a local maplins one
would tis be suffiencet?
http://www.maplin.co.uk/Search.aspx?criteria=ct100&menu=0&WorldSearch=Y&do y=9m9&ShowPics=true&Stock=28&MinPrice=0&MaxPrice=9 999&SD=true
Old 09-09-2006   #9
beintot
Posts: n/a
hi,the maplins ct100 cable is very high quality,it's £1.29 a metre i think,don't know who makes it,but it's much thicker than webro cable and also the foil inside the cable is a lot thicker than webro,i've bought both,i was more impressed with the maplins stuff,but i bought a few metres too short 25 instead of 28 metres and didn't want to add a join or extension so i've had to use webro instead which is inferior in my view.
Old 09-09-2006   #10
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
If you look around then you will find a 100mtr drum of CT100 for a LOT less than £129.
If not then I'll give up my day job.
L.
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 09-09-2006   #11
misterminibus's Avatar
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought.
wicks have a good cheap one too its either 50mtr or 100mtr for just over twenty quid...
I bought the silvercrest full system last year and if you have the same one the coax supplied if fine, I have it on 13* and its great...
ps does anyone know if their are any patches available to get anything on the
silvercrest-comag box ?
misterminibus is offline   Reply With Quote
Old 09-09-2006   #12
ahh i went over to maplins and bought maself 10mt of that ct100 cable
works like a charm! managed to pick up channels and all....thanks!
Old 09-09-2006   #13
Ding Dang Doo
gameboy's Avatar
Well done.
Welcome to the world of satellite TV - have fun.
Old 09-09-2006   #14
aint no going back now.... lol
Old 09-09-2006   #15
rolfw's Avatar
Real name: Rolf
Well done whoimi, glad to see you got it sorted.
At bientot, CT100 and WF100 are both made by the same company now and whilst the foil in CT100 is slightly thicker, the performance of the two cables is pretty much identical, with WF100 having the advantage of a foam dialectric and being less susceptible to denting and kinking.
I use hundreds of metres of cable per month and WF100 (along with its bigger brothers) is my cable of choice and in no way whatsoever inferior to CT100, I have used both extensively.
At mrminibus, don't know what cable was supplied with the kit last year, but this year's cable is RG59 and loses 8 to 10 db over the 12 metres or so provided, this could be the kiss of death on reception of all but the strongest satellites with the small dish provided.
Rolf
Old 10-09-2006   #16
* rolf
I have just had a look and its rg59.... this is rubbish then eh?
Mine looks ok sat in the box behind the sofa where it has been since I bought it... I have played with the stb but not the dish or coax as I put it on my 88cm dish, although the satfinder which came with it works great.... its an audio only meter and doesn't tell you which sat your on but if you use a compass first its great at fine tuning with this meter...Hi-tech I know
Old 10-09-2006   #17
rolfw's Avatar
Real name: Rolf
Those little satbeepers are great, certainly 100% easier than trying to align without one.
Rolf
Old 13-09-2006   #18
I did it the hard way before it took ages but its nearly a pleasure with a beeper..
my next quest is getting dplus on this silvercrest sl65 any ideas ?
can I do it with a rs232 or do I need to make one of these jtag thingimibobs?
Old 13-09-2006   #19
Ding Dang Doo
gameboy's Avatar
It's gone for now, hopefully not for long - just watch for all the d+ posts appearing again.
Old 13-09-2006   #20
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
I got RG59 with my porty kit, and it was rubbish and is still coiled up in my cupboard, and I sold the RG59 with the 57cm dish I took my SL65 and twin LNB out of...
Just to make me look like a numpty, erm, D+???
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 13-09-2006   #21
lots o stuff on astra 1, fox, nat geo loads of films, pple and arts this is good for american chopper if ur a petrol head... interested?
cable, dish, lidl, lnb
[IMG] code is Off
