Power supply problem in Humax 5350Information exchange on digital satellite systems other than Sky | |
| Member Join Date: 07-12-2003
Any of you who have got a diagram of the Humax PSU used in 5350 or any idea why my receiver have blown a resistor R21 (from front of PCB), left hand corner. If possible I would like to now the resistance of R21. Thanks | ||
| Member Join Date: 01-01-2000 Location: pj::
| Hi, I believe the 5400 psu is similar to the 5350.....R21 is in the list below...... Humax psu fault list List of parts you will need: = Use 105 degree caps not 85 C09 1000uF 16v 105°C C10 1000uF 16v 105°C C13 1000uF 25v 105°C C14 1000uF 25v 105°C C15 470uF 25v 105°C C16 470uF 25v 105°C C17 220uF 50v 105°C C18 220uF 50v 105°C C19 100uF 50v 105°C C20 100uF 50v 105°C C21 1uF 50v 105°C You can use if you wish 110°C and a higher voltage. R21 100 Ohm You can use a 0.25w but I used a 0.6w ZD3 30v Zener Diode 1.3w -------------- 1000uf capacitor [slimline] replace with 105 degree version, 10ohm resistor and 33 volt zener. You will see them as soon as you open it up. Thanks 2 the authors Regards B | ||
| pc:: | |||
| 5350, humax, power, problem, supply |
Similar Threads | ||||
| problem with power supply of galaxis | Soledad Torres | Digital systems | 1 | 10-09-2005 11:45 AM |
| Humax 5100 or Humax 5400z | internetbasic2000 | Digital systems | 9 | 28-05-2004 03:04 PM |
| Humax Power supply | Shogun | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 11-04-2004 10:14 AM |
| Humax targets UK DTT market | net1 | Terrestrial Television, Digital and Analogue | 0 | 26-09-2003 07:19 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
