Technomate 1500ci help/adviceInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 25-01-2007 Location: Europe
My System: Currently none! |
Guys A good friend has asked me to pick him up a Technomate 1500ci. He's living in Turkey, has 3 dishes up one for hotbird one for turksat and one for nilesat. He was advised by the local shop to buy an amstrad but an expat advised he'd be better off with a technomate as this can be patched to emulate encryption systems What type of kit will he need with the technomate, will the recv on its own suffice, is it possb to buy one with all the patches installed, basically if someone can just post a list of all that he will need ie cables, cams , blank cards etc that will keep him going. He was told the tps is open at the mo but the more he invests in the technomate the better. My knoweldge is virtually non exisitant so i may have missed things off etc... Any help will be appreciated. cheers | ||
| Member Join Date: 22-02-2005
| Tell your friend to get the Technomate TM-1500 CI+ Super. Make sure it's the Super model because it can do a blind scan much faster than the regular TM-1500 CI+. He won't need anything else, he'll just have to get the latest auto update patch from the ***** website. He can get it there for free | ||
| Super Nutty Mod Join Date: 03-10-2003 Location: Essex
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka ! | Much as Nicky says except that he will need a null modem cable to connect his PC to the receiver so he can download patches etc. They are very cheap less than a fiver, and of course he will need a PC with internet connection. The Technomate receiver's are very easy to use and are reasonable cheap. | ||
My System: Currently none! | thanx guys, just want to confirm he definitely wont need a dragon cards or viaccess cams or card readers not that i know what any of em do lol etc just the technomate and a null cable. He found out that it opened channels on hotbird will work on turksat or nilesat to? | ||
| | #5 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | No - Nilesat uses an encryption system not compromised on the Technomate. Most of the pay channels on Turksat use Videoguard and the same is true for them. He will get the free channels of course. | ||
| | #6 | |||
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka ! | But be warned that these "free" channels can come and go very easily. | |||
| | #7 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | yes the technomate is worth it as theres currently open premiere and digital + 19east, tv cabo 30west and tps/multivision hotbird 13east showtime is apparently open with gamma card on nilesat which also opens nova on hotbird but the card is 99 quid and you need a cas3 to program it | ||
| 1500ci, help or advice, technomate |
