Help me out please
Information exchange on digital satellite systems other than Sky
Old 28-05-2007   #1
My System: amd athlon 3ghz , 2gig ram 250gig hd
Smile Help me out please
Hi everybody
First time ive been here but im hoping that someone might be able to shine some light on my little problem for me.
Ive just purchaes the skyline DSR4000 satellite receiver kit
ive setted it up and all seemed well ,signal strenght 63% and quality 76% which according to the manually is pretty good .
It receives loads and loads of channels ,obviously a lot of scrabled ones which dont play but i expected that .but when i select a channel it plays for about 10 seconds or so the the receiver seems to reset and it closes the channel for a few seconds then comes back on
All the bbc and itv and radio channels play ok but lots of others just have this problem .Im pretty new to sats but if the signal and picture quality is good to start with why do i loose the picture after 10 secound
Many thanks
rickyboy
rickyboy is offline   Reply With Quote
Old 28-05-2007   #2
Robbo's Avatar
Real name: Mark
Are there any trees in the way of the dish?
Old 28-05-2007   #3
no m8
No its on my roof ther are no obstructions what so ever
just clear skys but tell me do you think that roof flashing could do some probs but then the other channels work ok
Old 28-05-2007   #4
Robbo's Avatar
Real name: Mark
You need to establish whether there is a fault with you dish setup or a fault with your receiver. One easy way to check this is to try another receiver or try somebody elses dish. Could the wind be blowing the dish out of alignment when it blows hard, and then springing back when its calm, or is it exactly 10 seconds each time?
Oh and yes, it is possible that some channels work and others don't, as there are a number of transponders which are operating on different frequencies, and either horizontal or vertical polarisation. This means that the signal level at your receiver is not necessarily the same for every transponder.
Old 28-05-2007   #5
Smile
it seems very consistant very close to the same timing out for it to be a wind cause but i know what your saying.thats a good idea , try another receiver ummmmm.is it possible that certain channels that i need to subscribe to will give me a little preview and then exit or am i talking shi------------t
Old 28-05-2007   #6
Robbo's Avatar
Real name: Mark
I'm sorry, I don't know about previews as I have only scanned in FTA. If all the FTAs work, but the subscription ones are intermiittent then this probably rules out a dish problem.
Old 28-05-2007   #7
Amo Amas Amant Admin
Topper's Avatar
Well
I am not certain but it would appear that you have either an Antsat sony-sat or skyline DSR 4000 receiver and as you say it is FTA. On 28.2 there are 3 types of transmissions (excluding HD) there are FTA free to air FTV free to view with an appropriate freeview card and there are subscription channels with an appropriate subscription. Are you able to identify the channels and list the ones that are displaying for 10 seconds?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 29-05-2007   #8
Many thanks
i will dispaly some of the channels that are not displaying but cant do it right now unfortunatly eill post tomorrow
once again mant thanks
rick
Old 30-05-2007   #9
sorted
Hi Fellas
The proble seemed to have sorted it self out
Switch the receiver back on the next day and alls fine
uuummmm bad weather maybe i dont know but its fine know
thanks fellas
rickyboy
[IMG] code is Off
