Feed difference?
Old 03-08-2007   #1
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
Feed difference?
Just having bought another channel master dish, It came with a feed horn, but has a cover on the edge.
Is there a difference between the two pictured?
The numbers are the same.
What is the advantage or disadvantage of the the plastic cover?
Feed difference?-feed-jpg   Feed difference?-feed-1-jpg
CROSSBONES is offline   Reply With Quote
Old 03-08-2007   #2
rolfw's Avatar
Real name: Rolf
I have a couple with and a one without, I guess that it keeps the rain off of the membrane.
Rolf
The Following User Says Thank You to rolfw For This Useful Post:
CROSSBONES (04-08-2007)
Old 03-08-2007   #3
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
interesting mine is like one on the left, the right one must be to stop the rain getting on the feedhorn
also is the right one abit longer in size ?
Old 04-08-2007   #4
CROSSBONES's Avatar
No there the same size wod, the cover makes it look longer.
I will try both and measure with my satlook micro.
Just want this rain to stop now
Old 04-08-2007   #5
rolfw's Avatar
Real name: Rolf
Crumbs, 30 degrees here and Bright sunshine with clear skies.
Rolf
Old 04-08-2007   #6
CROSSBONES's Avatar
Yes wish I were back in Oxford!
But back in rainy Wales
Old 05-08-2007   #7
izefisherman's Avatar
My System: Ku: 2.4m Aerial PFA / Invacom SNF-031, C: 1.2m Aerial PFA / MTI 15k, DM7020-S, DM500S, C-Tech 2100, VBOXII
Raindrops and snow will not accumulate so easily on the black plastic cover. Furthermore any water or snow that resists falling off it will be away from the phase center of the horn and should degrade reception less than if it was just on front of the horn as with the membrane version. The black colour will also help the sun melt off any snow much faster.
Wet sticky snow that builds up on the feed of an offset dish is probably one of the major reasons for temporary bad reception up here in the north. The dishes are pointing very low here (elevation typically 13-20 deg for "normal" satellites) and so the LNB is pointing upwards.Easy to cure if the dish is low and easy to clean off but a pain if the dish is roof-mounted since the cause of the problem makes one very reluctant to go up and fix it.
I would pick the black-cover version anytime provided the cover doesn't introduce losses over the membrane.
izefisherman is offline   Reply With Quote
The Following User Says Thank You to izefisherman For This Useful Post:
CROSSBONES (05-08-2007)
difference, feed
[IMG] code is Off
