very basic questionInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 05-08-2007 Location: turkey
My System: broadband - no saellite as yet |
Starting from point zero. Any advice much appreciated. I want to receive Uk television - except sky - in Turkey. I live in izmir. I have broadband but its quite slow. Turkish system seems to be 2 dishes via a "box" I have seen the list of channels - but most are not english language. What is the best way to receive uk tv in Izmir. through computer or direct from satellite. What equipment will I need? Mapins have a high definition FTA satellite receiver on sale - do I need this piece of kit? Thanks Chris | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, the only satellites that the UK channels are broadcast on are the 28.2E/28.5E (Astra1/Eurobird1). The problem is that most of the FTA ones are on the ASTRA2 2D beam which is focussed tightly on the UK. Other FTA are on 28.5 fixed beam The FTA channels available on the above sat cluster are listed here:- __http://www.lyngsat.com/28east.html The ones with an 'F' in column 4 are FTA. For the 2D channels you will need a very big dish, check here:- http://www.satellites.co.uk/satellite/VBGooglemap.php For the 28.5 channels a smaller dish (1.2-1.5m) according to Lyngsat. Only one dish is required to pick up both 28.2 and 28.5. You don't need a HD receiver, any of the FTA receivers in Maplin will do, or FTA satelite receivers from elsewhere also. regards. | ||
| lula member Join Date: 10-01-2005 Location: dublin, ireland
My System: humax 5400 fortecstar sl65 quali tv ir 4 digiboxes dragon cam funcard7 sm3d12 motor wavefrontier t90 90cm dish 1m dish | you'll need a very big dish no matter what type of receiver you buy. have a look in this section for more info http://www.satellites.co.uk/satellit...eception-tech/ | ||
Gigfy | |||
Thanks for the replies. Still not sure how to proceed. I could fit a dish with max diameter of 2m if necessary but would this bring uk channels in range? what other equipement do I need? any recommendations? Will I still need to re-programme or can this be done autmatically? | ||
| basic, question |
