Sattalite on a BOAT ??Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 09-08-2007 Location: United Kingdom
My System: Technomate TM-1000 D Super |
hi i am new to satallite tv and i was wondering if there would be any chance i could recive it on a boat ?? and the most it would move would be about 5 degrees! and another question a have a sky dish with a thompson LNB can i use that for astra 2 28.2E with my Technomate or do i need a diffren LNB ?? thanks for the help! | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, Your _Sky dish setup is fine to use with a technomate. Any movement of the dish even by 5 degrees would mis-align it. I belive that you can get dish setps designed specifically for boats, where the dish is aligned automatically. A google search should provide more info. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | dom1269 (09-08-2007) |
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | For what purpose? | ||
| | #5 | ||
My System: Technomate TM-1000 D Super | to not loose signal when the boat swings out a few degrees and does the satallite have to be bang on ie if it was ment to be at 28.2 and it wa at 27.8 would i still get a signal? | ||
| | #6 | |||
| ASBO Club Team Spokesmen Join Date: 30-10-2005 Location: Behind pin 9 on an atmel
Blog Entries: 2 My System: Dm500, TM9100, Pace Sky+ box, 1M Dish. Motect 2100.. 43Inch Plasma, Wii, PS2. | As said in an earlier post there is an item like spirit level which will correct it.. and keep the dish in its positition. | |||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The dishes for boats have gyro stabilisation, but they are of course not very cheap, click here. | ||
| | #8 | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | Maybe you could construct some sort of pivot & weight system which keeps the dish straight at any angle at which the boat is at, or there are some pretty expensive, but effective, self-adjusting boat & caravan/motorhome dishes which can do the same job... ![]() (rolf beat me to it!!!) If you're on the canal or river, just sit the dish on the ground, either on a tripod or a pole hammered into the ground when you're moored up... ![]() I've seen a few narrowboats round here which have minidishes and even Lidl or Maplin portable kit dishes fitted, and I guess that they work pretty well on the boats, but there are the odd few on a pole in the ground... | ||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | |||
| boat, sattalite |
