help needed please
Thread Tools Display Modes
Old 10-09-2007   #1
My System: thats what i'm here for
help needed please
hi
hope someone can help me.
at the min i have a 80cm dish pointing at hotbird to pick up art for last years premiership football, so now i've decided to switch to digitalb for this years premiership football, i have a 80cm dish, a humax 5400 reciver. and i'm located in Northern ireland.
what is needed for me to pick up digitalb at Eutelsat W-2 @ 16 east ?
the reciver has 2 Common Interface slots.
so do i need a Conax Cam ?
and the dish realigned ?
and the digitalb card ?
is that all i need or am i missing anything ?
all help welcomed.
thanks
DUVET is offline   Reply With Quote
Old 10-09-2007   #2
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
If your receiver has not got a card reader with an embedded Conax cam or equivalent then Yes, you will need a Conax CAM.
Yes the dish will need to be re-aligned.
Yes, you will need a DigitalB card, 'super sports' I believe its called, and it costs from about £132 for 12 months.
One thing you may want to do, is to make sure that your dish is big enough.This can be done before subscribing by checking that you get a good enough signal quality on those channels.
Old 10-09-2007   #3
Originally Posted by Robbo71 View Post
how do you check if your getting a good enough signal on those channels ? sorry if its a daft question, i know very little about it if i'm honest.
Old 10-09-2007   #4
Robbo's Avatar
First, you need to align the dish to 16E.
It's 3 degrees east and a bit lower than Hotbird.
(Mark your current position, so you can easily go back to it)
Then once you've confirmed that you can pick up some channels from 16E (consult Lyngsat)., Scan the transponder for the 'Super sports' on DigitalB, and check signal quality using the receiver's meter.
I can't get 16E on my dish as it's too small, so I could't tell you what transponder they're on.
The Following User Says Thank You to Robbo For This Useful Post:
DUVET (11-09-2007)
[IMG] code is Off
Forum Jump
