Do I need an amp ?? | |
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro |
hi to all like everyone else im trying to squeeze everything out of my set up,ive just measured the cable run and its longer than i thought ..23m to be exact do i need an amp on my 1.2m dish,will it help get the very weak signals just that bit better thanks iwol | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I wouldn't consider using an in-line amp unless you have a cable run of >35m. It's going to introduce noise particularly on low-level signals; best to concentrate on upgrading your cable (use something like WF125) or maybe a better low-noise LNB if you haven't one already. Llew | ||
