Skew on motorized systems | |
| Regular Member Join Date: 18-11-2003
I am right in thinking that with you leave the skew set to zero on a KU band motorized system? Reason is I having big probs with Foxturk on 33e and thought I might try fiddling a bit but seem to remember that motorized dishes set their own skew at they turn and tilt.
__________________ Now I'm hiding in Honduras I'm a desperate man Send lawyers, guns and money The s*** has hit the fan Warren Zevon | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You can always try, a small adjustment may improve it, I'm sure that the orientation of different satellites can vary by a small amount.
__________________ | |||
| | #3 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Are you sure you H-H motor arc is working properly? | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | Also due to manufacturing tolerances, LNB's can be the odd deg. or two out, can make a difference on weak signals.
__________________ Oldgeezer | ||
| | #5 | ||
| My arc is very nice, thank you very much. Sadly, my TM9100 is pants.
