Prime Focus LNB | |
| Member Join Date: 13-04-2006 Location: edinburgh
My System: 1.8m |
Im a bit confused as to how to set up an LNB, feedhorn for a prime focus dish. Should the focus point be at the throat of the feedhorn or at the rings of the feedhorn? | ||
| Specialist Contributor Join Date: 28-05-2003 Location: Florence Italy
| It should be at the throat,good info is available at www.mlsat.com/tutorial.html. | ||
| | #4 | |||
My System: 1.8m |
