monoblock 10 and 16 degrees
Thread Tools Display Modes
Old 15-09-2007   #1
bog standard
moosegoose's Avatar
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2.
hi wanted to get some romainia fta stuff from eutelsat w2 10 and 16 degrees will a monoblock and 80cm dish do im based in norfolk.according to lyngsat it looks ok but as i never tried it so i thought i just check.thanks in advance.
moosegoose is offline   Reply With Quote
Old 15-09-2007   #2
Nasty Dish Obsession
Lancelot's Avatar
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H
...And thou were the truest friend to thy lover that ever bestrad horse..."
Depends on the transponder(s) you're after there. Both 10E and 16E can be a bit of a struggle at times especially in wet weather.
Go for it is the answer, but remember to set the centre LNB on the dish to the weaker transponder/satellite that you need,
Rgds
L.
__________________
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 15-09-2007   #3
My System: Sky; Raven 90 with LNBs for 1W, 7E, 13E 16E and 19E; Technomate 1500 and Kathrein Analogue Receivers
Also, if you haven't bought the monoblock yet, consider using two separate LNBs instead --- though that would then require a diseqc switch.
bigtee is offline   Reply With Quote
Old 15-09-2007   #4
Le Basseur's Avatar
My System: Old 1.2 m Andrews Channel Master dish,MTI Supreme Line Universal Twin,Axing SKB95-01 cables,Nokia Mediamaster 9800S,Pace MSP991 positioner
Hi Moosegoose,
Take a look here:
http://www.satcodx1.com/0100/eng/
As you can see,the Eutelsat W1 at 10,0 East doesn't carry ANY Romanian TV prog.However,there used to be some "Romanian stuff" on this satellite but AFAIK,they're moved a long time ago.
Actually,the best way to get Romanian FTA's is to have a motorised system instead of a fixed dish w. monoblock/dual LNB combination.This way,you might be able sweeping between Amos and Intelsat 902.
HTH!
Regards,
Le Basseur is offline   Reply With Quote
Old 15-09-2007   #5
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
Here is a list of where the Romanian channels can be located
_http://www.flysat.com/tv-ro.php
Parky
Park Royal is offline   Reply With Quote
Old 15-09-2007   #6
Le Basseur's Avatar
Hi Parky,
This is what I was talking about...the link you posted contains some outdated Romanian FTA transponders (I have myself several similar links but I gave up watching them for obvious reasons...they update too slow).
For instance,as I already said,the W1 @ 10 East @ 11131 V doesn't have anything Romanian.The "Antena" package moved on W2 @13 East.
Anyway....if you want correct info,watch for lyngsat or either satco.
Regards,
Old 15-09-2007   #7
Amo Amas Amant Admin
Topper's Avatar
Cool Ermm
Just to avoid further confusion W2 which does have the Antena Package is actually at 16 East
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
Le Basseur (16-09-2007)
Old 16-09-2007   #8
Le Basseur's Avatar
Yep,my mistake!
Thanks Topper!
Regards,
[IMG] code is Off
Forum Jump
