channel master 1.2 setup help | |
| Member Join Date: 22-10-2004 Location: derry city n.ireland
My System: dm7000s set up for ca*d sharing......full packages. 1.1 metre triax dish-motorised-superjack 2. small sat dishes for hotbird.and 28.2. |
im setting up a channel master 1.2 for my mate.i ive used this page : http://www.satsig.net/maps/lat-long-finder.htm and it tells me my latitude is 54degrees and i should use the dish elevation of 24.7 degrees to receive THOR my most southerly satelitte. so my question is : i take this angle to be set at position "x" on the attatched drawing, and my latitude of 54 degrees to be set at position y on drawing....is this correct???? when im pointed at thor my complete setup should be set "straight" at thor as it is my highest point on the arc......again ?????? any help is appreciated.as ive bought the same dish and trying to get my mates sorted first as his is easier to access to tweak | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | From Belfast your most southerly satellite is not Thor, 5W is closer, only a degree away.
__________________ | |||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Try to visualise what your dish should be pointing at to receive the satellites on the arc. I did a quick drawing to help you visualise what is out there
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #4 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. |
The adjustment that just tilts the dish up and down is used to adjust the declination i.e to get the correct dish elevation for your nearest sat. The declination can be adjusted for maximum signal, once you're all connected up. Last edited by Robbo; 15-09-2007 at 11:28 PM | |||
| The Following User Says Thank You to Robbo For This Useful Post: | poolshark (16-09-2007) |
| | #5 | ||
My System: dm7000s set up for ca*d sharing......full packages. 1.1 metre triax dish-motorised-superjack 2. small sat dishes for hotbird.and 28.2. | i forgot to mention im in derry and my longitude is 7 degrees west......so surely i will be starting with thor ? when ive got thor strong, should i then move my polar mount 7 degrees????? Last edited by poolshark; 16-09-2007 at 04:52 PM | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You'd be better off notching your polarmount 1 degree West and aligning on 8W in that case http://www.lyngsat.com/8west.html, either that or nothing it 2 degrees East and using 5W. I can see no reasn at all why you would line up on 1W.
| | #7 | |||
thanks roflw, so you mean leave polar mount pointing where it is at currently (thor), and align dish to 8west? | |||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The polarmount should have a small allowance for whichever satellite you choose as mentioned above, so if you choose 5W, then allow 2 degrees Eastward, 8 West would be 1 degree Westward.
| | #9 | ||
so if i do what i said in my last post i should be able to get the dish on the arc then? | ||
| | #10 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I'm not sure what you meant by "so you mean leave polar mount pointing where it is at currently (thor)", forget Thor, but your polarmount should be at dead centre plus or minus the degrees to your nearest due South satellite.
| | #11 | ||
My System: dm7000s set up for ca*d sharing......full packages. 1.1 metre triax dish-motorised-superjack 2. small sat dishes for hotbird.and 28.2. | this is confusing.......currently the polar mount is dead centre and the dish is pointing at thor. 0.8 w. so if i just turn the dish and locate 8w (thats allowing me the difference of 7 degrees).like you said above "You'd be better off notching your polarmount 1 degree West and aligning on 8W in that case" | ||
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Move the whole assembly on the mast, forget 1West it is not your due South.
| | #13 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | surprised you have got it aligned as 5west or 8west is very strong and the 1.2m dish should get it easily but you will need to be more precise with alignement due to the tighter focus on the satellite | ||
| | #14 | ||
My System: dm7000s set up for ca*d sharing......full packages. 1.1 metre triax dish-motorised-superjack 2. small sat dishes for hotbird.and 28.2. | thanks.ive forgot about thor........im moving the whole assembly to 8 degrees west. now this is what you said "but your polarmount should be at dead centre plus or minus the degrees to your nearest due South" | ||
