Manhattan Starlight 6900
Thread Tools Display Modes
Old 18-09-2007   #1
misterminibus's Avatar
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought.
MANHATTAN STARLIGHT 6900 are they any good ?
I have the option to buy one can they be patched will they operate a 36v motor ok?
__________________
Tis better to be thought a fool and remain silent than to open one's mouth and remove all doubt.
misterminibus is offline   Reply With Quote
Old 19-09-2007   #2
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
hi !
i dont know this modell ,only have the older 5900 starlight,have all motorconections ground gnd pulse and so on,it has usals,but no m1 and m2 conections,on the backside,so iam wondering,how i can move 36 v,psoitioniers when this 2 importend conections are missing?
in combination with usals?
bought it in auktion house,first,after search it does not store any channels,and reboot new,i make complete reset,works good in kuband know,but i find no posiblity ,to change,the lnb lof ,when i want search cband channels,i manually selected singel stack or somesthing like this called ,what i can coose,and then,the channels search,only goes 5 secunds,and dont find,any channels,and reboot new!
also have the old 2500 version with 3500 sofware older menu that have all conections on the backside,but on sofware menu its unable to select the 36 volt option ,only diseqec ,that i can select,now iam looking for the better manhattan plaza,but i dont find it here for a good price,no dealer have manhattan here
the menus,are a little bit complex,to handel,on all manhattan reveivers,espaselly,on the older ones
theese,are all information,what i have at the moment?
i often herard,that the voltage output ,are more stable,then on echostar resveivers,some told me on the net,the motors would be move faster with manhattan reseivers,coses there,comes more power out?
can anyone confirm this?
ps_i dont know,that there,is any patch,avalible for any models
upgrading manhatten reveivers,you can also use cas 3 interfaces!
is it,on the plaza series posible ,to store,the scew settings,speratly per transponder,on echostar,it is only posible,for each/singel satelite
Turok is offline   Reply With Quote
Old 19-09-2007   #3
I hav an echostar and I can't really see how one stb can move a motor quicker than another as all it does is supply power to the motor and remove the power when its direction change is complete . I like the plazza it's menus are better than my echostar but it can't do 36v and I don't want to change my motor...
__________________
[IMG] code is Off
Forum Jump
