so i got the 1224 motor today .... | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish |
the 1224 motor arrived from hm sat de along with a vbox my word how come its so big and quite heavy, my wall mount isn't going to take it so going to add to it so shall that be enough was wondering if there will be no need for the top t bracket and just leave 2 k brackets with t in middle ? any tips as well to setting up as one of them angle finders i though to get the motor elevation correct etc ? align the dish/motor to thor 1west and then bobs your uncle as they say ? | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hi! do you have complitly free range 360 grad on your roof,with out any objects in the way,on my smr 1224,i have removed the limits inside the motor,other wise it wil not range the full range! | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | i cant put it on the roof as houses in england aren't built with roof terraces so it has to be wall mounted | ||
