signal prob-nova tv in uk
Thread Tools Display Modes
Old 19-09-2007   #1
My System: hot bird 80cm dish, manhattan plaza xt-cm,nova tv subscription
I live in Huddersfield, W.Yorkshire and have just had an installation to get Greek TV. My set up is an 80cm Hotbird Dish, positioned 13degrees east, Manhattan Plaza XT-CM Receiver with built in Irdeto, and a Nova TV card. I keep having problems with the picture freezing, or total loss of a channel. One minute I have been watching a channel, next thing the screen the pic has gone, and it says on top of the screen, "scrambled/no audio/video". I have checked on the setup menu and my signal is shown at 64%, quality 89%? Is this a signal problem, and if so any ideas please on how to sort it!
cgblueman is offline   Reply With Quote
Old 19-09-2007   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum cgblueman
Well it will really be a process of elimination to sort this out. Presumably this this a fixed dish, if so what happens when you view an FTA channel, is the picture constant?
If so this suggests that it is a decryption problem, what version of Irdeto is the built in cam, it should be Irdeto II, are you sure the card is inserted all the way? Is the receiver new and has it been guaranteed to work on Nova?
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
cgblueman (20-09-2007)
Old 20-09-2007   #3
Thanks for the reply. Yes it is a fixed dish, and when I view channels through hotbird the picture is fine.
I have looked in the manual, and I cannot specifically see whether or not it has irdeto II. The engineer who installed it said it would be okay with Nova, but I am not convinced!!! I have tried taking the card out and ensuring it is re-inserted fully, but it is still the same.
Old 20-09-2007   #4
Topper's Avatar
Well
Presumably this is the model
Manhattan Plaza XT-CM Digital Receiver (XWSR/16)
Product Description...
The Manahattan Plaza XT-CM is packed full of features including a 6,000 channel memory, very fast blindscan search, two multi-crypt embedded card slots and one common interface slot. Working with a whole host of cards and encryption systems including Greek Nova Irdeto.
The brand new Plaza XT-CM features a blind scan mode, a 1-45,000 symbol rate range and full DiSEqC and USALS support and can be used as part of an SCR (Single Cable Router) system. Up to 11 favourite TV and radio lists can be created and channel data can be edited on a PC via the RS232 port. There's also a nine channel mosaic preview mode and a selection of games to play.Connections include LNB and UHF loopthroughs, two Scarts, a composite video output, stereo phonos and an SP/DIF audio output.
The modulator is adjustable 21-69. The technical specifications are too numerous to list in this description. Please call if you require a full spec.
If this is the one and the engineer installed it to allow you to watch Nova and you cannot do do then you are perfectly within your rights to contact him and get him to sort it.
__________________
Show Your Support
Thank you.
[IMG] code is Off
Forum Jump
