Recommendations For Receiver With 36V Positioner | |
| Member Join Date: 29-03-2004
Hi, Can anyone recommend a digital receiver with inbuilt 36V positioner that has a decent tuner signal threshold. The Echostar DVR7000 that I am currently using is not very sensitive to weak signals. I am using an Invacom 0.3db LNB but still no good for some of the signals. If I use my old Nokia 9600 with the signal I get pics straight away. However, I would prefer an all in one box solution preferably with DVB recording. I think Manhattan used to make one but I am not sure if there are any manufacturers still producing high spec mototrised receivers anymore with an inbuilt 36V positioner. Any advice greatly appreciated. Rgds | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | There are not many receivers made with 36v inbuilt. You would be better off getting a vbox II | ||
