Spec me a dish
Thread Tools Display Modes
Old 22-09-2007   #1
My System: [Sky Digital (Sky+ Pace 3100)] [80CM Solid Nokia Dish] [Echostar 3000.]
Spec me a dish
Could somebody spec me a 1m dish for around £50 please? (Solid, white)
I have seen a few orbitals on Ebay for £40 (1m) are these anygood?
wolfboy is offline   Reply With Quote
Old 22-09-2007   #2
rolfw's Avatar
Haven't tried one I'm afraid, but have seen them advertised. I've found with some of the budget entries into the market, that they are made very cheaply and do not perform particularly well.
Update Jan 2008: Did manage to look at one, November time and wasn't impressed with the build quality, particularly the AZEL bracket.
__________________
Rolf
Donate
Old 22-09-2007   #3
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased...
The Sleepy Hollow pollracle has spoken!
You could have had my channel master dish that I had on Ebay , it's 1m in white and very very solid, it unfortunately sold for £25 though...
__________________
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 25-09-2007   #4
Damn, may mate has a 1.2m channel master and it is superb.
Is there a section where I can put a wanted plea in??
Old 25-09-2007   #5
2cvbloke's Avatar
The buyer's not contacted me yet so there may be a chance of selling it again...
Anyway, there's a Classified ads section of the forum here for you to place an ad for pretty much anything...
http://www.satellites.co.uk/php-bin/...ieds/index.php
__________________
Old 26-09-2007   #6
If the guy off the bay doesnt get in touch, count me in.
Old 26-09-2007   #7
2cvbloke's Avatar
Well I have one guy interested in the stand so it may just be the dish & VSAT feedhorn (no LNB, but a decent C120 LNB's good) on it's own...
__________________
Old 26-09-2007   #8
Ok, thats fine mate. I'd be mounting it on my pole anyway so don't really need the stand.
Old 26-09-2007   #9
2cvbloke's Avatar
It'd need to be a 3 inch pole as it's a hefty dish...
__________________
Old 26-09-2007   #10
I've got a 2 inch pole but it's clamped in two places so is very sturdy etc and is filled with cement.
Do you reckon it would be stong enough?
Old 26-09-2007   #11
2cvbloke's Avatar
Well, the mount would go over the pole, but you wouldn't get it tightened up!!!
Anyway, I've just got a message from the buyer, so it should be gone by the weekend...
__________________
Old 26-09-2007   #12
Ahh well never mind then. I'll have to keep looking around for one
Old 26-09-2007   #13
What dish do you recommend I have a look for? I don't mind buying used, don't really fancy ripping my pole out so it'd need to fit a 2" pole.
1m, has to be white and be compatible with my Moteck SG2100 motor !
Old 26-09-2007   #14
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
gibertini do a white or rather light grey aluminium dish that will fit a 2 inch pole no problem and they do a polar mount so you can motorise the dish
sizes range from 60cm up to 1.5metre
theres also triax 1.1m, funke 1metre or keep a look out on Ebay for a used channel master i'm sure there was a 1.2m version going on there, then you could fit a jaeger 1224 motor to the dish
Old 26-09-2007   #15
Don't really fancy getting a new motor etc as my Moteck is not very old.
I'm running an 80cm, unbranded, white solid atm with a 0.3db lnb which is great for the strong sats but feeds etc off 16east I can't lock onto.
Got a feeling the gain on the dish isn't the best.
I'm pushing my luck with an 80cm tbh as I don't want to upset the other half lol. Was thinking of giving a triax td88 a go.
What are the reviews like on these?
Old 26-09-2007   #16
rolfw's Avatar
They perform quite well, have used quite a few, shame i haven't had an opportunity to campare it against the Fracarro Penta 85cm yet.
__________________
Rolf
Donate
Old 24-01-2008   #17
rolfw's Avatar
Update on this thread, have now installed a few Fracarro Penta 85cm dishes and they definitely outperform a Triax TD88 and Raven Gemini 90cm dish, have to day installed one to a Moteck SG-2100, this was the steel faced version and it is heavier than the Aluminium version, but still performs very well. A neat compact solution for a motorised dish.
If you can get hold of one, it is worth the extra money to get the Aluminium version.
For the resident pedants, you will have already noticed that the middle K bracket is slightly offset, not intentional, just that it was from a different manufacturer and was reversed. It was also much thinner gauge steel and too thin for heavy dish mounting, I will check the thickness later so that members can check that their suppliers are not using this light weight bracket.
__________________
Rolf
Donate
Old 24-01-2008   #18
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
So Rolf do you recommend the Fracarro Pentas? Ive been toying with the idea of one for our Sky installation - just because its different
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Old 24-01-2008   #19
rolfw's Avatar
Yes Ross, cracking dish, easily assembled, good solid construction with sensible features like coach bolts for the elevation adjustment, only one hand required for tightening (unlike some other dishes) and the steel bracketry will not cut your hands to pieces like the Raven and Triax.
The LNB holder has adapters for 25mm, 40mm and 60mm units, so should be fine for the new 3 degree monobloc LNBs, all this and good solid performance.
As mentioned above, if you are looking to motorise, go for the aluminium version.
__________________
Rolf
Donate
Old 24-01-2008   #20
wod
i cant see how that dish is better than a triax 88cm as the dish surface area is less
have you tried one against a 1metre dish to see if the claim is true of it being better than a 1metre dish ?
Old 24-01-2008   #21
rolfw's Avatar
Believe me it is better than the Triax 88cm wod, it is better made for a start and that will always make a difference, don't know about the 1m comparison, as I haven't got one to compare it with, but I do doubt that it would beat a quality 1m dish.
__________________
Rolf
Donate
Old 28-01-2008   #22
asdrianst's Avatar
My System: Tofield Xp
Thank you rolfw,
it that it be possible you can take size dish to know how much it size “really” because on another forum somebody say which size is 100 from top to bottom and 90 of width.
thanks in advance.
asdrianst is offline   Reply With Quote
Old 28-01-2008   #23
rolfw's Avatar
Haven't got one in stock to measure at the moment, but will have one by the weekend hopefully, so will measure then. From memory the height is taller than 85cm, I think that is the measurement across the square sides.
PS. Will be installing a 3 degree monobloc on one later in the week as well, so will be able to assess how well it performs with 16E and 13 E on the same dish.
__________________
Rolf
Donate
Old 28-01-2008   #24
asdrianst's Avatar
Thank rolfw
i wait your response for "real" dish size.
Old 31-01-2008   #25
asdrianst's Avatar
hello rolfw
do you have take others images with Fracarro Penta?
do you try get a satellites in the extreme example Turksat or Hispasat with penta 85?
you think that can be posed a problem the shape of the antenna for the extreme satellites example Turksat or Hispasat?
thanks a lot
ps:I await measurements of the dish impatiently if you can take them of course
