jaeger 1224
Thread Tools Display Modes
Old 22-09-2007   #1
CROSSBONES's Avatar
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card.
jaeger 1224
How many members use the 1224 motor?
What size dish do you use on it etc.
Any one have the strengthened version?
CROSSBONES is offline   Reply With Quote
Old 22-09-2007   #2
My System: Various
I tried a 2.4M dish on one and it moved it effortlessly from 0 elevation. But it could not cope with wind and would have been damaged eventually. I think a 1.8M dish is the absolute max for exposed areas.
Orthoclipse is offline   Reply With Quote
The Following 2 Users Say Thank You to Orthoclipse For This Useful Post:
CROSSBONES (23-09-2007), Lancelot (23-09-2007)
Old 23-09-2007   #3
Crossbones,
I use one on a Precision 1.5M prime focus dish. I have had it for at least 10 years now and it still works perfectly. Its the best bit of sat equipment I have ever bought, lasted ages longer than some of my "cards"
One point though, when it comes out of the box you may need to adjust the mechanical E/W limits in the casing otherwise it will have a truncated arc. Its easy to do and instructions should be with the paperwork.
I have not heard of the "strengthened" version, what aspect of it is "strengthened" ?
rgds
moonbase is offline   Reply With Quote
The Following User Says Thank You to moonbase For This Useful Post:
Old 23-09-2007   #4
CROSSBONES's Avatar
Thanks for the input guys.
Orthoclipse, what was the dish made from?
moonbase, here is a pic of the stronger 1224. I was debating about mounting my C/master 1.8 on it.
But I think its too heavy and wont risk it.
Old 23-09-2007   #5
My System: I use a 1.2 Gregorian dish connected to four receivers including a scopus 4.2.2 professional ird2800 and Echostar3600 and two blind scan rx's. My lnb is a quad invacom. All rx's are linked to my packard bell easy one silver laptop.
Looks like that an additional plate that holds the Incline jack bolt to the base of the 1224, I think on or two bases have snapped as in the picture with the wind. Looks like that could be a fairly easy diy job though.
Thanks Crossbones.
BTW, I have a 1.8 Precision on a 1224, I think that would be my limit and certainly a Channel Master 1.8 would be really pushing it with the weight.
scopus is offline   Reply With Quote
The Following User Says Thank You to scopus For This Useful Post:
Old 23-09-2007   #6
CROSSBONES's Avatar
Yes I have seen the pics, very nice too
That metal plate does look an easy mod to do. But the
prices on that German site are very good.
Old 23-09-2007   #7
Yes..certainly better than 'rip off britain'
Old 23-09-2007   #8
My System: Various
55kgs of "precision engineered" Jonsa steel.
There are some people mounting 2.4M and 3M mesh antennas on them, but the wind load would be much lower.
There used to be a sturdier version, the SMO-36 (2nd picture) but it is no longer manfactured. Satshop24 stock the KM 1012 and use a 3.7M mesh on it.
h**p://forum.dxtv.de/wbb/thread.php?threadid=7090
Old 24-09-2007   #9
CROSSBONES's Avatar
great thread with an even greater dish!
Satshop24 are out of stock of the KM 1012.
I did look at that motor when I nearly bought a prodeline 3.1m.
Also considered the Egis but out of my price range!
[IMG] code is Off
Forum Jump
