Transparent Dishes - Good or Crap?
Thread Tools Display Modes
Old 24-09-2007   #1
garym71's Avatar
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable
Does anyone have any experience of using the transparent dishes?
I'm drawn to purchasing an 85cm one for a 3 LNB fixed dish setup (Astra 2 [28E], Astra 1 [19E] and Hotbird [13E]) mainly because I have no real option other than to put the dish on the front wall of my house so I want to try and make it as inconspicuous as possible. However, if these are known to be crap then I will need to reconsider my options.
Last edited by garym71; 24-09-2007 at 09:02 PM Reason: Removed website link to external company as these aren't allowed on the forum
garym71 is offline   Reply With Quote
Old 24-09-2007   #2
rolfw's Avatar
I've seen one of the 65cm ones from there and the bracket was very flimsy, don't know about the 85cm they have. I have an 85cm Vector industries dish and it performs about the same as most other cheap to medium range dishes, as do a couple of others I've fitted.
__________________
Rolf
Donate
Old 24-09-2007   #3
garym71's Avatar
They do say part the way down the page on their site that the 85cm one is a newer design with better reinforcement so hopefully it is better than the one you previously saw...
The pictures middle & the right shows our new clear 85cm dish. This dish is clearer than the older type on the left and is stronger with re-inforcing structures on the back of the dish. The older discontinued dish on the left has been included so you can size it against a person. The new dish also uses a slimmer back plate which adds to the abilty to see right through it.
Do you happen to know how the clear ones reflect the satellite signal onto the LNB? Do they have some kind of special coating on? This is what I'm mostly concerned about...that the reflective properties will be of a poorer quality than on the metal solid/mesh dishes.
Old 24-09-2007   #4
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
The ones that I have seen have a wire mesh embeded into the plastic, the wire mesh being the reflective surface.
Parky
Park Royal is offline   Reply With Quote
Old 24-09-2007   #5
garym71's Avatar
On closer inspection of the pictures on the suppiers website it looks like you might actually be right. Although the images aren't that great it does look like there might be some type of micro-mesh moulded into the plastic. I didn't notice this before and just assumed they were 100% clear plastic.
Old 24-09-2007   #6
rolfw's Avatar
They all have the mesh, otherwise they would not reflect the signal.
__________________
Rolf
Donate
Old 25-09-2007   #7
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
I have an 85cm transparent dish and it works fine but I've nothing to compare it to. When it rains heavily I tend to lose all signals.
As to how inconspicuous they are I think a normal dish painted the same colour as the wall it is mounted on may be more inconspicuous .
__________________
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 25-09-2007   #8
dasteelman's Avatar
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card
i agree ..........
__________________
Nice but Dim
dasteelman is offline   Reply With Quote
Old 25-09-2007   #9
garym71's Avatar
Other than it probably being quite difficult to get paint to match the colour of my house bricks, I also have 2 different colours of bricks in the walls so I think trying to paint a dish the same colour as the walls will just end up with it looking a complete mess to be honest so I think I'd be better off just taking my chances with a transparent one.
If only my house wasn't South facing I would be able to put it on the back and not care about the colour
[IMG] code is Off
Forum Jump
