Help needed | |
| Member Join Date: 24-09-2007 Location: MANCHESTER/BRADFORD
My System: no satellite as of yet...help needed |
Hi everyone, i was wondering if someone could help me, I’m completely new to this satellite stuff, so please be patient.. ![]() I want to buy a new motorised system, was thinking about a technomate receiver with a 1 metre dish, can forum members recommend which receiver and which dish to buy!! And where to buy from? Plus the dish must be black, as will be getting it installed at my girlfriends who lives in Bradford, as she lives in one of those country houses with black stone, a white dish would stick out like a sore thumb....so black dish is needed.. Ps: is a 1 metre dish legal? Or do i need planning permission? Thanks in advance.. | ||
| | #2 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
![]() As for a black dish, it's easier just to buy a normal white or grey dish, then using matt-black car paint just spray it black or maybe be arty and match the brick pattern of the house... ![]() You can find allsorts of kits through the advertiser's banners at the top of the page...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| The Following User Says Thank You to 2cvbloke For This Useful Post: | Rich-Tea (24-09-2007) |
| | #3 | |||
will check things out. | |||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | No probs, just a quick note, the Technomate 1500 series are quite popular for their patchability for "extra" channels...
| | #5 | |||
My System: no satellite as of yet...help needed | Would you recommend buying a full system off Ebay | |||
| | #6 | |||
You can buy a full system from Ebay
| | #7 | |||
I’ll settle for a technomate 1500, on your advice, can you recommend a good dish? It’s got to withstand heavy wind and stuff, where her in doors lives, it gets wind/snow the lot, its right in the hills, so it’s got to be pretty sturdy. The colour doesn’t matter now, i’ll take your advice again, and use car spray paint on it... Thanks again mate, you’ve been really helpful | |||
| | #8 | |||
As for surviving strong winds and bad weather, you'll need to use a set of T & K brackets, as the sheap "L" brackets will just flex about, and in some cases they have even snapped off leaving the dish dangling by it's cable or on the ground with a big dent!!! Also, T&K setups are best suited to motorised setups as they're much more stable, but you have to make sure it's straight and vertical otherwise the dish won't be properly aligned to the satellite arc...
| | #9 | |||
| | #10 | ||
My System: no satellite as of yet...help needed | Oh just reading on a website, and i wondered which would be the best for me with having bad weather conditions, a Diseqc motor or a 36 volt motor? | ||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | 36v without a doubt.
__________________ | |||
