Dish Size for Measat3 in Qatar | |
| Member Join Date: 25-09-2007 Location: Doha, Qatar
My System: Hotbird Nilesat Measat3 91.3' |
Hi guys, need some advice in selecting the correct dish size and correct LNB. FYI, I'm in Doha, Qatar and trying to get Measat3 signal of Malaysia TV channel. ![]() Really hope some advice from the expert here... | ||
| | #2 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | RTM 1 is carried on the Global beam of Measat 3. According to the Lyngsat map http://www.lyngsat-maps.com/maps/mea3_global.html most of the Middle East is under the 37dbW contour which suggest 1.65 m should be the minimum you are looking at.
__________________ | |||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | No idea, Ive never used c-band equipment. There are various c-band lnb's mentioned across the form - use the search function to see which ones other folks use.
