Hotbird 13E & Astra 28.8E on a 60cm Dish
Thread Tools Display Modes
Old 27-09-2007   #1
garym71's Avatar
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable
If I just want to pick up just Hotbird 13E and Astra 28.8E with 2 LNB's on a single fixed dish setup (I'm located in the south of the UK), would a 60cm dish be sufficient or do I really need an 80cm dish to achieve good signals from 2 satellites with a 12.8 degree separation?
Thanks,
Gary
garym71 is offline   Reply With Quote
Old 27-09-2007   #2
rolfw's Avatar
Go for a Raven Gemini 70cm with Eastern sats offset bracket, should be fine.
__________________
Rolf
Donate
Old 27-09-2007   #3
garym71's Avatar
That doesn't look a bad option actually. Would a 70cm dish also support receiving of a third satellite on 19.2E as well as 28.8E and 13E because I'm still in a dilemma as to whether or not to bother with 19.2E for now and maybe just add it later if I so decide.
Old 27-09-2007   #4
rolfw's Avatar
Yes, have set up several for all three.
__________________
Rolf
Donate
Old 27-09-2007   #5
garym71's Avatar
Rolf, what LNB's did you use on the setups you installed? Might not really make a lot of difference but maybe I would be better using ones that had been successfully tried and tested with the Raven dish.
Also, am I correct in assuming you're talking about the Raven Gemini 70cm MESH dish (i.e. not a solid one)?
Old 27-09-2007   #6
rolfw's Avatar
I've used the solid Geminis mostly, the LNBs have varied, but most modern quality LNBs will do the job.
__________________
Rolf
Donate
Old 30-09-2007   #7
CROSSBONES's Avatar
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card.
You could also use a zone 2 sky dish, but you have to extend the lnb arm by 2".
rolfw`s way is probably the best and easiest way.
CROSSBONES is offline   Reply With Quote
Old 01-10-2007   #8
p
My System: 90cm gregorian 5way zone2
im south UK and now running a zone 2 set up
p is offline   Reply With Quote
[IMG] code is Off
Forum Jump
