Wall mount distance.
Thread Tools Display Modes
Old 29-09-2007   #1
TJExcalibur's Avatar
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800
I am deciding on whether to have a 1.2 or 1.5 dish. I think (if I have worked it out right) the elevation for Bournemouth is 32 degrees, +or-. If correct I am able to have the 1.5 dish because of the angle it will not show above the window. I am trying to work out what depth of wall bracket I need for a motorised system. I have seen a 2 ft deep one which looks sturdy. I did try to suss it out with a round piece of cardboard but the other half got fed up with holding it at the angle whilst I turned it. Unable to find the answer in the foruns.
Thanks.
__________________
It's not what you know or who you know but what they know.
TJExcalibur is offline   Reply With Quote
Old 29-09-2007   #2
Prince of Birthdays
dig deep's Avatar
My System: Dream7020 and lots of junk all over the place
This is a try and test problem mate
Climb a ladder, bring a paper dish and try it
dig deep is offline   Reply With Quote
Old 29-09-2007   #3
Many thanks. I will have to give it a go, although I can access the wall from a flat roof so its just waiting for a still day.
__________________
Old 30-09-2007   #4
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
You should be able to get a rough assessment by doing a 'scale' drawing.
Noting how far the bracket sticks out from the back of the dish, how far the motor sticks out, and the relative position of your wall to due south, beforehand.
Robbo
Old 01-10-2007   #5
Thanks for the replies. Umable to put the dish where I thought as it would hit the wall on the east location, unless I use a long standoff. But will put on another wall.
__________________
Old 01-10-2007   #6
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
1.2 dish will be too small for satisfactory reception of C-band, is that what you are considering?
__________________
Llew is online now   Reply With Quote
Old 01-10-2007   #7
Thanks Llew.... Not even sure what size dish yet but it will be an Andrews with 36v motor. I worked out whare the dish need to point to W to E from info on the web. it never stated what band so I do not know the W to E limits on each band. The more I read the more I forget..must be old age.
__________________
Old 01-10-2007   #8
Llew's Avatar
I've placed this thread in the general Dish Setup section from the C-band section, you may have more answers here.
__________________
[IMG] code is Off
Forum Jump
