Minimum size dish for Monoblock | |
| Member Join Date: 29-09-2007 Location: Birmingham England
My System: Comag SL65/12 Camping Set with added Monoblock Universal LNB |
I have a Comag SL65/12 camping kit and have fitted a monoblock to it so i can view both Astra 19 and Hotbird 13. Trouble is i can't quite manage to get both at the same time at one dish position. The dish is a circular 35cm type. Has anyone managed to set up a monoblock on this size dish? and if not, what's the minimum size i need to view both satellites from a Monoblock at one dish position. Any advice greatly received. Last edited by chrisuk1; 30-09-2007 at 04:36 PM | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Use a bigger dish is my advice, 35cm dish is too small to get both with a monobloc. As regards which dish size will be required I could only guess to be honest and my guess would be 60-70cm
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
My System: Comag SL65/12 Camping Set with added Monoblock Universal LNB | Cheers Topper, i've spent all day trying different combinations but i reckon you're right the dish just aint big enough. Have to trawl through Maplins website and see if i can pick something up there. Hope i can get away with a 43cm high 60cm wide elliptical one. | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Look for something like a Raven Gemini 70cm, should do the job well.
__________________ | |||
| | #5 | ||
My System: Comag SL65/12 Camping Set with added Monoblock Universal LNB | Thanks rolfw, problem is i live in a flat and the dish will be on my balcony so discretion is a must. Unfortunately in this case size does matter Lol | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | OK, then you could try a 60cm transparent dish, should work OK with the monobloc LNB.
| | #8 | ||
My System: Comag SL65/12 Camping Set with added Monoblock Universal LNB | Well i've done it guys, i bought a 65cm elliptical dish and it works fine with the monoblock. I now get both Astra 19 and Hotbird 13 without moving dish, only thing is i had to compromise on the signal quality to get about 55% on Astra and 60% on Hotbird, but it's good enough for now. Thanks for all your advice people. | ||
| | #9 | ||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | Glad you got sorted and your landlord will probably not be any the wiser
