1224 Motor
Thread Tools Display Modes
Old 01-10-2007   #1
My System: Not setup yet
1224 Motor
Hello everyone,
What is the range of the 1224 motor? I have just installed mine and using the vbox is doesnt appear to move more than around 25 degress east or west before the "err" on the vbox.
modk is offline   Reply With Quote
Old 01-10-2007   #2
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
did you alter the limits on the motor ?
also if its the version with the inclined orbit jack then it wont move as far
Old 01-10-2007   #3
rolfw's Avatar
Look at the mechanical limits, it should have a 180 degree azimuth range.
__________________
Rolf
Donate
Old 01-10-2007   #4
No........ do they need to be "altered" to reach the maximum?
Old 01-10-2007   #5
Thanks, but the instructions I received we're rather lacking to say the least - either that or they were not designed to be read by complete newbies
Old 01-10-2007   #6
Just reading the instructions
THe H-H mount has factory preset mechanical limits for protection
I will open it up and check this in the morning, getting a bit dark now
Old 02-10-2007   #7
CROSSBONES's Avatar
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card.
Take a look here.
jaeger 1224
CROSSBONES is offline   Reply With Quote
Old 07-10-2007   #8
hello again
What I've noticed on the vbox is that the range displayed is between 0 and 1000 - when infact is should be 0 and 2000 (displayed with a dot index) however mine only goes from 0 to 1000 before the ER2. When I set it to around ~550 I pick up Thor (which is central south) but then it only counts 500 points either west or east of that and goes no where near as far as even 30 west/east. I would have thought it would be displaying near the zero mark for Thor and then travel between -1000 and +1000.
I've tried to reset the vbox and also the limit settings but it makes no difference I only get a 1000 range.
Anyone have any ideas?
Old 07-10-2007   #9
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
Originally Posted by modk View Post
hello again
Although only displaying 999 the 'V box' does keep track of greater counts, (well both mine do anyway).
The 1224 gives around 25 counts per deg.
Starting from 000
1W counts down to 980 on the display
39E counts down to 024 on display
45E counts down and rolls over to give 888 on display
30W counts up to 666 on display.
Any help
__________________
Oldgeezer
johnsattuk is offline   Reply With Quote
Old 07-10-2007   #10
Starting from 000
Any help
thanks for that - its what i thought - yours travels through 2000 counts with thor being at roughly 1000 moving 1000 both east and west of that.
Mine on the other hand has thor at around 520 and only goes to 0 and 1000. Half the range......... - and only moves the dish half the range. anyone else ever had ths problem
Old 07-10-2007   #11
Oldgeezer
johnsattuk's Avatar
Mine moves more than +- 1000
My E limit is set at 500, that is 1500 counts eastward
The wall limits me on the W side, but I know from previous experience that it will do just the same westward.
Not in a position to try it, but I am sure it will do +- 2000 counts, maybe even +- 3000
Just got my spare 'Vbox' out and coupled to a spare Fibo motor, seems to be OK up to 3000 counts in both directions. Repositions the motor OK.
__________________
Oldgeezer
Old 14-10-2007   #12
Thanks for that - I appear to have fixed it - vbox just needed a reset (i thought i had done this countless times last week but after doing it again seems to have worked). Box now displays 0 at start and then revolves between -1000 and +1000 which takes the dish a nice 180 ish degrees.
One question I have is that when it is set to 0 and it is facing due south - I insert my usals for my region and then on the receiver (TM9100) I say go to Thor 1W. I expect the vbox to send a few pules to the dish and for it to move a few degrees ... but no, the vbox starts to count all the way west and keeps going until i manually stop it somewhere around 50W. Why does it now know how many degrees off due south it needs to move?
Old 14-10-2007   #13
rolfw's Avatar
The V-Box is not USALS compatible as far as I know, so won't work, you will have to stick with DiseqC 1.2.
__________________
Rolf
Donate
Old 14-10-2007   #14
ahh that explains it
so once Ive got the motor all alligned I just store the sat positions?
[IMG] code is Off
Forum Jump
