1.8 Channel Master. Adding inclined tracking?
Thread Tools Display Modes
Old 03-10-2007   #1
My System: 1.8 motorised Channel Master Quali tv+ Manhattan 500
Hi,I have a 1.8 Channel master which is currently moved across the arc using an large actuator. I am toying with the idea of adding inclined tracking to it.The only idea i have so far is to replace the inclination bolt with another actuator.Has anyone tried this with any sucess before or is the a smarter solution?.Thanks Mike
mikeysat is offline   Reply With Quote
Old 03-10-2007   #2
Amo Amas Amant Admin
Topper's Avatar
Mmm
Well lets put it this way, it would have to be a very special motor with gearbox to make the miniscule alterations for an inclined orbit adjustment with any accuracy. It would also have to have tremendous torque to raise the weight of a 1.8mtr, I'm not saying it cannot be done indeed I am pretty sure someone posted on here a while ago whose kit could do just that but for what you get back it seems a lot of messing around, what exactly is it that entices you to go down this road?
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 04-10-2007   #3
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
the jaeger 1224EL motor does inclined orbit but think the andrews dish is too heavy for it even thought the spec it says 1.2m-2.4m dish
Old 04-10-2007   #4
keano's Avatar
My System: 2.4mtr Channel Master Dish, Fracarro Penta 85cm Dish, 64cm Traix Dish with 4 multi LNB'S Sky HD, Dreambox 800, Dreambox 500, IPBOX 250, Sky HD and a mad wife !
Guys my 2.4mtr CM dish as a arm each for both east west and incline decline.
It works perfect for incline and decline.
keano is offline   Reply With Quote
Old 04-10-2007   #5
Hi,The main reason is to follow 8 and 20 west it doesnt move a huge amount but i am currently adjusting it manually which is a pain,as it throws my positioner out of sync.The 2.4 c/m. Any chance of seeing the setup behind the dish also what size jack are you using?.Cheers
Old 04-10-2007   #6
keano's Avatar
yes m8 I will get you a picture tomorrow when I get home from work.
Finish at 2 on Friday, so it gives me 3 hours before wife gets home.
We've had words again tonight about the dish, I may have to look at lowering it in to the ground, so a bit of digging this weekend might be in order.
She is complaining about the height
Frigging women !
Old 05-10-2007   #7
CROSSBONES's Avatar
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card.
Put her in the hole instead mate!
Would like to see some pics too.
CROSSBONES is offline   Reply With Quote
Old 05-10-2007   #8
keano's Avatar
Here you go m8,
Pictures for you of the two arms moving my dish.
Old 05-10-2007   #9
TJExcalibur's Avatar
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800
Some dish! Don't the neighbours complain or does the trellis hide it well but it must affect the signal.
Originally Posted by keano View Post
Here you go m8,
__________________
It's not what you know or who you know but what they know.
TJExcalibur is offline   Reply With Quote
Old 05-10-2007   #10
keano's Avatar
Neighbours have not said anything its just the bl**dy wife.
The trellis is at the side and the dish is mainly on 7.0w so trellis does effect it.
I am thinking of going in front with trellis and plants because the signal actual comes from above and not directly in front.
I can stand right in front of the dish where the LNB is there is no loss of signal.
Old 05-10-2007   #11
CROSSBONES's Avatar
Nice pics!
So its not on a polar mount, Is it hard finding sat`s with the 2 motor`s?
As you have to adjust both motor`s every time you move the dish.
Old 05-10-2007   #12
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased...
The Sleepy Hollow pollracle has spoken!
Just out of curiosity, there's a DOS program I posted a while back called FODTRACK, which is used with 2 axis HAM radio antenna dishes, would that be of use with these setups?
Here's the homepage for it:
_http://ludens.cl/Electron/fodtrack/fodtrack.html
Here's an adaptation of it's use:
_http://www.geocities.com/yyz228/
__________________
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 06-10-2007   #13
keano's Avatar
Originally Posted by CROSSBONES View Post
Nice pics!
At the mo m8, I have only gone from 1.0w to 7.0w.
It went from 7.0w to 4.0w with out having to use incline or decline.
The only problem is the slot on the mount are small and will only allow lets say 5.0e to about 12.0w.
If thats make sense.
I have ordered a feedhorn from snap and can't wait to try it because at the mo current feedhorn is not good enough.
My and wife had a very long chat last night and have come to a comprise I have to do my best to hide it ( don't laugh ) within the next month.
So it will be a case of lowering it and getting conifers/plant to put round it.
Old 06-10-2007   #14
Rd100
Posts: n/a
The 2.4m andrew (channel master) are good dishes i have installed loads in the past for one way rx only and two rx/tx and they work well,
They need the andrews feedhorn with a F/D of 0.66 with a VSWR of
1.3:1
otherwise your 2.4 will act as a 1.8m dish,
The feedhorn you need is below
Andrew Part number: 611-6060-07
Corrugated ku-band linear feedhorn
vswr 1.3:1
F/D 0.66
Old 06-10-2007   #15
thanks for the pictures iou.RD.Are you able to get them any cheaper as your in the installing game?.I would like to get oneand trade my 1.8 in at the same time if you know of any one whose interested.mike
Old 06-10-2007   #16
CROSSBONES's Avatar
Here are some pics of the small C/master polar mount with decline angle motor fitted.
Might give you some idea`s.
Old 07-10-2007   #17
Hi Crossbones,Thats a good piece of ingenuity. I was unable to see exactley how u managed to get inclination to work.Have you a pivot pin or something similar.Mike
Old 07-10-2007   #18
keano's Avatar
1.3:1
Andrew Part number: 611-6060-07 611-6062-07
vswr 1.3:1
F/D 0.66
Thanks m8,
I have ordered one from snap so hopefully things should be OK then.
Old 07-10-2007   #19
CROSSBONES's Avatar
Its not my dish, its from a member called scopus. Maybe if you contacted him he could give you more info on it
Old 07-10-2007   #20
Rd100
Posts: n/a
What is the point in adding inclined tracking on a small ku-band 1.8m dish i could see the point on a large C/KU BAND 3M 4M + dish but on a small dish is the uk there is no point,
Old 07-10-2007   #21
An interesting point but can you tell me why? I read somewhere a while back that adding inclined tracking enabled adjustement if needed without climbing up to the dish. As the cost of a 1224EL is little more compared with the cost of 1224 I thought it was maybe worth it.
__________________
Old 07-10-2007   #22
Rd,For someone who installs dishes i am surprised you ask such a questionYou can find alot if you know where to check espically in the u.k.
Old 07-10-2007   #23
Rd100
Posts: n/a
I don't just install dishes but all sort of broadcast gear,
What i am saying in the ku-band over the uk there is not enuf inclined orbit satellites that need a small dish dish that need tracking i can understand on a large dish but for a 1.8m on ku-band its pointless
Old 07-10-2007   #24
Rd100
Posts: n/a
If the polar mount or HtoH mount or gear driven mount is set up good in the first place then you would not need it,
The type of dishes that need inclined orbit tracking are not the type you could put on the side of your house,
I have installed alot of large 2 axis dishes and they have inclined orbit tracking to track inclined orbit satellites and to adjust as the beamwidth is so tight, When i use to have a 3.1m dish a few year back as the beamwidth was so tight if you was on say eurobird 28.5 east you would have to move the dish to watch any thing on the astra birds at 28.2 east due to the beamwidth the bigger the dish you go the narrow the beamwidth gets,
Also just to add the only satellites which would need inclined orbit track on a 1.8m dish in the uk are below but i do not think any channels broadcast on them so it is pointless,
Optus A3 inclined at 8.92°
Telecom 2C inclined at 3.51°
Telstar 11 inclined at 3.12°
On my new prodelin Series 1374-1375 3.7m dish it will have inclined tracking but this is due to the size of the dish you can see the dish here http://www.gdsatcom.com/Antennas/Dat.../3-34-37ro.pdf
I did want to get this one and could have had it http://www.gdsatcom.com/Antennas/Data_Sheets/45ro.pdf but that is OTT,
The Following User Says Thank You to For This Useful Post:
TJExcalibur (07-10-2007)
Old 07-10-2007   #25
It is nice to have it clarified. Being a newbie it takes ages to get all the info together and to avoid wasting money on not needed gadgets. Will stick to the 1224.
__________________
[IMG] code is Off
Forum Jump
