CT150 Cable | |
| Regular Member Join Date: 20-07-2007 Location: London
My System: Channel Master 1.2m and 1.8m, Vantage VT-X221TS CI and 8000s, Technomate V-Box II, 18" Superjack actuator |
I've read around that CT150 cable is the best cable to use when the signal being received is low. The trouble is that I would like to try this out but a google search doesn't bring much up. Is it known by another name and where can I get this type of cable from? | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Try searching for WF165 or CT165, don't think there is such a cable as CT150.
__________________ | |||
| Regular Member Join Date: 21-04-2007 Location: nottingham
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized | can you tell us what sort of length we are talking about | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | if your cable run is about 30-40m just use some wf125 | ||
| | #5 | ||
My System: Channel Master 1.2m and 1.8m, Vantage VT-X221TS CI and 8000s, Technomate V-Box II, 18" Superjack actuator | When it is installed it will probably be 40m, possible a bit more. I'm moving into a flat with a flat roof, so I'm looking at getting a 1.2m or 1.8m so want the best possible cable for fringe satellite reception. I don't want to have to change the cable so I want to use the best from the start. I saw RD100 mention CT150 on this forum and another forum as being good for improving the signal on weak signals. | ||
| | #6 | ||
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized | try ct 125 very good but very dear now 0r slitlly lower spects wf 125 but cheeper then ct 125 | ||
| | #7 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Hi, Info on CAI approved cables and their specs here: _http://www.cai.org.uk/asp/downloads.asp Robbo | ||
