what satellites | |
| abb Join Date: 03-10-2007 Location: hastings e.sussex
My System: technomate 7755 windows xp | hi every body can one tell me which satellites i can get with 86cm motek motorised dish i live in sunny hastings about 2minutes from the beach, my latitudes are 50.85 and my longitude is e0.33. best regards | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You should be able to get: Turksat 42E Hellas sat 39E Astra 2 28.2E Astra 1 19.2E Eutelsat 16E Hotbird 13E Eutelsat W1 10E Eutelsat W3A 7E Sirius 5E Thor 1W Atlantic Bird 3 5W Atlantic Bird 2 8W Atlantic Bird 1 12.5W Telstar 12 15W Hispasat 30W There are a couple of other on which you may be able to pick up a couple of channels, but this is a rough guide.
__________________ | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | You may also get some from Eurobird 3 at 33E | ||
My System: technomate 7755 windows xp | thanks robbo for your help ,would it make a diffrence if the dish is an alluminum mesh dish in other will i get the same satellites? best regards | ||
| | #5 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | No, I don't think it would. As what we call a 'mesh' dish is not really mesh, but a solid dish with loads of holes in it. The microwaves can't get through them little holes, the wavelength is too long. It's fine as long as the dish doesn't get distorted.Incidently, in reality being down there, right near the beach, you might be able to go from 45E to 58W, just seen a post elsewhere, a guy using an 80cm 'mesh' dish along the coast in Brighton, being able to do it. I think he even got a couple of verticals from Nilesat. Best way to find out, is to stick the dish up, get it all setup properly on the arc, and have a scan around. Is there a particular satellite you are after? | ||
| | #6 | ||
My System: technomate 7755 windows xp | hi robbo thanks or the info, i am trying to get as many as possible ,i just bought a tms 1500 receiver to replace my tm7755 because it has more upport. before i had a solid steel dish but where i am it didnt proove to be solid enough. it rusted away like nobodys business. regards. | ||
| | #7 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Well unfortunately the high salt content of the air in coastal areas tends to take its toll on all types of dishes steel and aluminium the best being clear perpex with embedded mesh and fibreglass with embedded mesh. You don't however say where you are in your profile.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #9 | ||
My System: technomate 7755 windows xp | hi topper you mentioned the fiber glass dishes immbeded with mesh can you point me to the right pace to get one. i looked very where with no luck .regards | ||
| | #10 | ||
I'm sorry I have not seen any being sold new for many years, I have had mine since the early eighties
| | #11 | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | there is also visiosat dishes these are smc fibreglass with embedded metal mesh and work well these will be a better option in your area _http://www.visiosat.com/home/gamme/category-index.php?cat=1 | |||
