2" alluminium pole strong enough for 80cm motorised system? | |
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Hi, there. Probably not. You'd be better off with a strong steel one. A scaffold pole from your local scaffholders will do the trick. Robbo P.S and have a good read through this as well mate. http://www.satellites.co.uk/satellit...or-others.html | ||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: technomate diseq 1500ci+ ibm thinkpad | | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I'd agree, a steel mast is a must, but having said that, mine's been running for several years now with an aluminiun mast (all I had at hand at the time). ![]() Reasons for Steel mast, stronger, more rigid and harder, a scaffold pole even better.
__________________ | |||
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | scaffold pole is better but they are weighty as i was redoing my system today and felt it when adjusting it for level need like 3 hands a steel pole 4mm thick should be ok aluminum pole would crush around the clamps on t&k brackets | ||
| | #6 | ||
| Donate to this board Join Date: 05-09-2006 Location: So called capital of Suffolk, UK.
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband. | As "wod" stated, 16gauge aluminium tube will start to deform as you tighten up the bolts on the brackets and the motor. Parky. | ||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | SGB at Willesden will have them, or most plant hire companies, otherwise look in Yellow Pages for a Steel Stockholder.
| | #9 | ||
| Regular Member Join Date: 21-04-2007 Location: nottingham
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized | ive got a 1 m motorised dish on a 7 ft aluminium scaffold pole on my chimney stack been there for years mind you the pole goes through the roof and there is only about 2 ft of pole abouve the top t & k bracket never had any problems with it mind you the brackets are about 5 ft apart | ||
| | #10 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I've used one of those as well, no problem at all with movement as they are very heavy guage, but still a little soft, as the motor bracket tends to dig into the aluminium.
