I need you opinions on this setup please. | |
| Regular Member Join Date: 09-01-2005 Location: Bournemouth
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | Spent ages reading these forums for info and advice and here is my intended setup. I face SW and intend placing the dish on the corner of a flat roofed building. This will give me 30 degrees E and W of south. Strapped to the wall with Hypex wall mount and pole above flat roof. The dish I chose was an Andrews 1.2 offset. Motor is a Jaeger 1224. Not sure if a prime focus would be better due to some large trees about 25 m away but should miss these. I thought offset meant the elevation was set lower. Matched feed horn but unsure of the LNB. Did consider a Fracarro 1.2 dish but unable to find much info on its quality and the fitting of a Jaeger 1224. The coax cable is WF 125 but maybe WF 100 will do for a 30 m run which will be in conduit. Receiver is a Technomate TM6900 HD. Looked at several others but I am no whiz kid and it’s a hobby, not a daily test of my brain capabilities. OK anything I missed and do pick it to bits, as it’s better now than later. All criticism and advice welcome. Not rich by any means but you get what you pay for.
__________________ It's not what you know or who you know but what they know. | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
No mention of a V-box or do I need to read it again?
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Good choice of dish and motor, they go great together ![]() Get the matched feed for the dish, and add an Inverto or invacom C120 lnb for great results. You will need a vbox as Topper has suggested, unless the Technomate has a 36v positoner | ||
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | Ah! Well I missed that out. Haven't looked at any so will do so now. Thanks!
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | andrews 1.2m on 1224 motor will be a very nice setup, good cable choice the 1224 motor will need a 3inch diameter pole lnb wise then an inverto c120 will be good choice if its on a flat roof then one of them ground mounts will work and weight it down with some paving slabs jaeger 1224 motor can be bought from hm-sat.de for 119 euro much cheaper than uk price | ||
| | #6 | ||
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | Thankyou for the info so far and the 1224 motor price. I do not want to do the same as I did when I built my computer, had bits over because they were not compatable. What a waste. Just waiting for the rain to stop and its fitting the conduit first job.
