Jaeger 1224 Installation QuestionsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | Table of corrected inclination/declination | ||
| Oldgeezer | |||
| | #27 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | so the jaeger is similar to diseqc motors then as i have set mine set to 53 latitude which is about 37 degrees for my location and then adjust the dish on thor with a satellite meter. just the instructions with the motor make it unclear | ||
| | #28 | |||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | The dish does not know or care if it is driven by a diseqc motor, a 36v motor, a Jack, a windscreen wiper motor or by hand, anything that moves it to the correct pos. is OK. | |||
| Oldgeezer | ||||
| | #29 | |||
| Regular Member Join Date: 09-01-2005 Location: Bournemouth
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | Now that is clear and you obviously know it will save me bolting the dish direct to the motor and then find it doesent work and having to take it off and fit the brackets. Maybe, with a bit of luck and if the weather stays fine I could have my first glipses of pics on my TV, Thanks for the advice and patience. ![]()
| It's not what you know or who you know but what they know. | ||||
| | #30 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | TJExcalibur, how far have you got with it all ? is it now setup and working ? | ||
| | #31 | ||
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | No. LNB holder came, set up th dish, well it can't be correct, got a strong signal on the meter, set it all up in front of TV and only get good signal 78%, quality 2%. I havent got a small TV with scart to put upstairs to see it all when moving the dish. Will have to move the heavy 32" up there. Plus, spend some time trying to figure out the dish settings, lnb skew and nearest satelitte again. Ive messed us somewhere so will even check all the connections tomorrow. Bit disappointing after ages of hard work with cables in trunking all nicely clipped etc. Would have been nice to have seen just one TV channel.....Ah well, tomorrows another day. ![]() David at Sat Super is giving me a carriage costs refund and apoligised for the TNT cock up. Invoice in the post...I hope. | ||
| | #32 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | what sat you aligning up at as thor should be very strong on a 1.2m dish bbc world on 11325 H, 24500, 7/8 which i use to align to which meter are you using ? you could slacken the adjustment bolts on the motor and see when the dish is tilted down or up the signal gets better ? also the feedhorn if using one have you adjusted this for best signal ? | ||
| | #33 | |||
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | I spent all day on checking everything from scratch. Alingment of the pole, compass setting, elevation etc. Even checked the cable plugs. Still signal strength 72% to 89%. Quality is 2% and does not alter. I think its the LNB so will try again Friday with a cheap one to see. The meter readings alter when I used it and I set the dish on that but still same results on receiver. ![]()
| | #34 | ||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | | ||
| Oldgeezer | |||
| | #35 | ||
My System: Andrews 1.2 dish. Inverto LNB. Matched feedhorn. Technomate 6800 | I set the elevation to 39 degrees and went a several degrees either side. Not sure where I got 39 from, been reading so much stuff but looking at Dishpointer it says Elevation:31.8°. Sod me......sent the LNB back but it least it will get tested and its only a few quid postage. Will have another try Friday......![]() | ||
| | #36 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | 39 degrees elevation on the motor ? the 39 degrees is that based on your latitude as you should set the motor to that if it correct for your area | ||
| | #37 | |||
The dish elevation given (31.9deg) is for a prime focus dish, not for an offset dish. It is sometimes referred to as the look angle of the dish. You need to subtract the offset angle of your dish from that figure Dishpointer also shows due south, and the azimuth of a chosen sat. Often you can zoom in to see a landmark to aim at, even if it is another building, tree, road junction, neighbour's shed. | |||
| Oldgeezer Last edited by johnsattuk; 15-11-2007 at 10:25 AM. Reason: emphasis | ||||
| | #38 | ||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | My Lat. is 52.5deg, corrected gives 53deg. giving motor angle of 37deg. It is generally the motor angle we quote and measure because it is the easiest, (90deg - 53deg) but what we are really after is to get the turning axis to 53deg. | ||
| Oldgeezer Last edited by johnsattuk; 15-11-2007 at 10:50 AM. | |||
| | #39 | ||
| Member Join Date: 11-08-2008 Location: Manchester
My System: Channelmaster 1.2m Dish Jaegar 1224 motor with inclined orbit option Tandberg T1222 & T1260 IRDs Custom-made dish positioner | Apologies for dragging up an old thread. I've got a Andrews/ChannelMaster 1.2 dish and 1224 motor with the additional inclined orbit motor. Can someone confirm my sums? Results from dishpointer.com using Thor/Intelsat @ 0.8W as my south sat: Site Lat: 53.5 degrees Site Lon: -2.3 degrees Dish Elevation: 28.9 degrees Dish Azimuth: 181.2 degrees magnetic So, I've found two tables for calculating the motor and dish declination angles. One table was part of the documentation I got with the motor. The other is the one posted by johnsattuk which is for a modified polar mount. I don't know which is the going to the right one. According to the instructions supplied with the motor the figures are as follows: Motor elevation: 35.83 degrees Dish declination: 6.93 degrees According to the modified chart table the figures are as follows: Motor elevation: 54.15 degrees (although this could possibly be 90 - 54.15 which results in 35.85 degrees) Dish declination: 6.92 degrees Also, looking on the 'net has yielded another method for calculating these figures: Motor elevation: 36.5 degrees (90 degrees - 53.5 degrees) Dish declination: 6.3 degrees (28.9 degrees dish elevation - 22.6 degrees dish offset angle) Which numbers are correct? This is all rather confusing. I've never set a motorized system up before. I've done plenty of fixed dishes in my time. Also, could someone explain the declination aspect of the setup? My understanding is that figure (6 degrees) is subtracted from the motor angle (as measured with an inclinometer on top of the motor housing as per the photo in the previous post). But how should I measure this? Assuming the dish and motor are installed with the motor at the set angle, should I measure by placing my inclinometer on the metal plate on the back of the dish? If so, what angle should I be looking for bearing in mind I'm using an offset dish (the offset angle is reported to be 22.6 degrees for that model). What I intend to do once I've figured out the correct motor and dish angles is to move my 1224 motor to 1.5 degrees east, loosen off the bolts on the pole and manually position the whole dish and motor assembly to get the best reception of Thor/Intelsat @ 0.8W. Once the dish is aligned correctly, I'll tighten all the bolts and then do a sweep of the arc and make sure I can see everything. Does that sound right? Any info would be greatly appreciated. | ||
| | #40 | ||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | The modified chart is a correction to compensate for the slightley non-spherical shape of the earth. The motor angle and alignment to the south, sets the mount up to be aligned with the axis of the earth. The declination angle sets the radius that the mount will describe at the equator ( clarke belt). The dish offset angle means that the dish needs to be tilted forward by this amount, so that it also looks at the same radius. This will mean that your dish in the zero pos. (due south) will be leaning back slightly (35.8 - 6.9 - 22.6) 6.3 deg. Because of measuring dificulties, manufacturing tolerances etc. this will almost certainly need a little tweak when you get a sat to align on. The figures supplied with the motor and the ones from the chart are very close to one another, I think it is unlikely that you would be able to set up these angles to 0.01 deg. , 0.1 deg is difficult in practice. I would suggest use 35.9 deg. for the motor, set as accurately as you can, lean the dish back about 6 deg. and go from there. | ||
| Oldgeezer | |||
| | #41 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | you cant really go wrong with this motor installing it. i fitted one at the weekend and have it tracking the arc 19e to 22west so far on my first go , not tried any further each side all i did was set the motor elevation to the correct degrees setting ( that is worked out from the posts above) then with a sat meter attached i aligned to thor and get the best signal by adjusting the top two offset brackets that attach to the adapter plate the dish will lean back slightly i've found with mine as the dish at thor will be at it highest in the arc | ||
| | #42 | ||
My System: Channelmaster 1.2m Dish Jaegar 1224 motor with inclined orbit option Tandberg T1222 & T1260 IRDs Custom-made dish positioner | Got it going this afternoon. Many thanks for the tips. Pretty impressed with the performance. Even with 120 meters of cabling I'm still getting +7db C/N on transponder F2U on Eurobird 1. I've attached a couple of photos of the installation. Bit of a pain to set up given that I've got to climb an access platform every time I need to adjust something! | ||
| 1224, installation, jaeger, questions |
