Please answer quikly?
Thread Tools Display Modes
Old 14-10-2007   #1
My System: ?
Dish is 90cm
I'm having Eutelsat 13.0E
is there a possible way to get
Eutelsat 28.0E too??
Or do i have to buy an another LNB?
Latitude 60
Longitude 30
bluffer is offline   Reply With Quote
Old 14-10-2007   #2
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
If you buy a motor you won't need another lnb.
__________________
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is online now   Reply With Quote
Old 15-10-2007   #3
My System: ClarkeTech 2100Plus USB + Triax 88DL+Moteck (Palm) 2100A motor, Home-Theatre AV System, LCD-TV, PC, HTC TyTN
yeah get a motor if you want to get more satellites...and I can tell you it isnt a piece of cake but if you really want it, then you will have the channels :d
bjluv is offline   Reply With Quote
Old 15-10-2007   #4
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Originally Posted by bluffer View Post
Dish is 90cm
Latitude 60
Longitude 30
Have a look at the footprint maps on
_http://www.lyngsat-maps.com
It looks like your dish is big enough,
To get it in addition to 13E, you will eiher need:-
An additional dish
An additional LNB ( plus bracket)
or a motor.
[IMG] code is Off
Forum Jump
