Motorised setup - is it rocket science?
Thread Tools Display Modes
Old 18-10-2007   #1
My System: Sky + looking for best patced receiver and motorised setup.
Talking Motorised setup - is it rocket science?
Hi all
I have just purchased an Echolink EL 3020 IR Super receiver and an 85cm dish with a satcatcher diseqc 1.2 motor.
The intention is to have a go at installing it myself but i am a bit overawed by the thought of it all. Is it really that difficult.
I am thinking about fixing the dish directly to the pole without the motor to start with, find a satellite and alter the dish inclination till i get the strongest signal. After that i could take the dish down attach the motor, refit it and try finding the satellites using USALS.
Does this make sense or would it be a waste of time because i might have to alter the dish inclination again after attaching the motor.
Sorry if this thread doesn't make sense but i am a newbie to this game.
Any advice on installation would be greatly appreciated and i would be chuffed if i could crack it myself before having to find a pro to fit it for me.
My lat/long is
lat 57.68277
long -2.01719
any recommendations welcome.
Regards
Proudbrocher
proudbrocher is offline   Reply With Quote
Old 18-10-2007   #2
rolfw's Avatar
Read my sticky thread on setting up a Moteck motor, shouldn't be any different for the Satcatcher, as it's probably a Moteck clone.
Once you have followed the setup instructions, then after entering your coordinates in the USALs menu, drive the motor to 1W (the only time you drive the dish with the motor prior to finding the correct arc) and by moving the whole lot on the mast and the elevation of the dish (declination) only, find 1W.
__________________
Rolf
Donate
The Following User Says Thank You to rolfw For This Useful Post:
proudbrocher (18-10-2007)
Old 18-10-2007   #3
bog standard
moosegoose's Avatar
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2.
hi it is not complicated just take it step by step.the first step is read the forum and find your feet.then you should pick the right location.south facing wall.with no obstructions ie trees ect.make sure u get your pole plum both ways as it is important to get it right a good spirit level will do nicely.good luck mate.
moosegoose is offline   Reply With Quote
The Following User Says Thank You to moosegoose For This Useful Post:
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
