Motek setup query | |
| Member Join Date: 07-02-2007 Location: London
My System: Dreambox 7025s, Gemini 26-10-2007, Moteck SG2100 Motor, 512k Broadband, 80cm dish |
Hi all, I'm in the process of setting up a dish with the latest Gemini image and a Moteck motor but I think I haven't got the LNB settings in Gemini set correctly. Can anybody tell me what the following settings should be and perhaps what they relate to : Tone Mode Toneburst Sequence Repeat Command Order Uncommitted DiSEqC Command DiSEqc repeats Thanks ![]() Last edited by heyjoe; 19-10-2007 at 01:57 PM. | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | None of those, you need to set it to complex DiseqC, or motorised DiseqC 1.2, which ever your image gives you the option for. ![]()
__________________ | |||
My System: Dreambox 7025s, Gemini 26-10-2007, Moteck SG2100 Motor, 512k Broadband, 80cm dish | I've been looking through the settings on my image but there doesn't seem to anything closer than the options I'm using. There's only one screen that allows me to select DiSEqc1.2 and that shows the options previously stated which may not need adjusting. Maybe there's another image someone can point me to. I've also been having problems manually moving my motor, don't know if that's related ? | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | When I go into Satellite configuration, it gives me a drop down menu at the top for Many satellites via a DiseqC rotor.
