Using C120 Feedhorn on Channelmaster? | |
| | #26 | |||
Besides anyone using a BUC on a motorised system needs to have additional VSAT licence requirements, ( usually covered by SNG status in the UK but may differ overseas). I would strongly advise a separate dish for the Internet over satellite system, allowing it to remain fixed and operational when looking for reception of satellite TV channels.
__________________ There is a very fine line between "hobby" and "mental illness" | |||
| | #27 | |||
| Guest
Posts: n/a
| I did not say he did need a vsat feed??? i was just telling him what a dual feedhorn is for i do know how vsat works i look after a fleet of vsat systems across the uk at broadcast and uplink sites I suggest you read post #17 again before jumping to concussions the part where i said "Also you are wrong with the requirements YOU ONLY need a dual linear / circular orthogonal for VSAT ( 2 way satellite Internet) as you need two ports one port for the c120 lnb and one for the BUC (transmitter)" .
| | #28 | |||
| Regular Member Join Date: 26-12-2004 Location: Wirral
My System: 1 metre Channel Master with matched feedhorn + Inverto 0.3dB lnb. 1224 H to H motor ground mounted. Technomate 5400CI+ USB and v-box | My cabling is about 45 metres....reception is superb. Frank | |||
| | #29 | |||
Besides, dual feeds are used in receive only systems , namely those that have dual band LNBs (11 and 12 GHz types) in a non 22kHz distribution network, or where the cost/logistics of installing a second dish is prohibitive.
| | #30 | ||
| Regular Member Join Date: 30-06-2007 Location: Brussels Belgium
My System: DB7000S HDD USB2GB; FTE MAX S102; 2CM120+ 2Norsat7706A on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E | Hi Channel Hopper, Could you expand further on the use of the: Ku Feed RxO 611606210 Polarization: dual linear, orthogonal. I posted a new thread on "fringe reception" concerning the invacom QPF quad LNB. Perhaps your lead will help conjugating these two elements for even better reception. | ||
| | #31 | |||
The type of LNB will be determined by your purchasing powers and availability, but there is not much performance difference between the well known brands on the market, I would notspend too much time looking at the paper statistics, buy one, fit it,and report.
| | #33 | ||
My System: DB7000S HDD USB2GB; FTE MAX S102; 2CM120+ 2Norsat7706A on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E | It is now clear that using single band LNB's is the most efficient way to go. One has to accept the idea of using one LNB per polarity. As any attempt to use switching will reduce SNR. But how about using two Norsat 4000A one for horizontal and the other for vertical? combining both on one feedhorn, specialised in the band selected, let us say 11.7 to 12.2 gHz. Could an Andrews vsat combiner hold both LNB's and feed them through the same feedhorn? I was thinking putting the verticals on the less advantaged BUC port. I have been oogling the items attached to this post. | ||
| | #35 | ||
My System: DB7000S HDD USB2GB; FTE MAX S102; 2CM120+ 2Norsat7706A on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E | I have no choice as I cannot use a bigger dish, simply because I am at the size limit with the CM120 and a bigger dish would require anchoring with bolts to the roof. Fantasy dreams are good drivers, they push you to investigate and, perhaps, finally find. The choice of LNB-feedhorn is the way to go. I already discovered thanks to you guys that using an Invacom QPF does not further the matter for me. I am forced now to fully investigate the more expensive way of using a Norsat4206A LNB for Horizontals and the cheaper NJR2744H KU DRO LNB for Verticals with one Andrew 611-6062-10 feedhorn, to provide both the horizontal and vertical polarities to a multiswitch. The 611-6062-10 provides, on both flanges, with the same VSWR of 1.3:1. This should cover for me with the CM120 dish, in Belgium, the critical band 11.7 to 12.2ghz (24/7, rain or shine) for Showtime and ADD on Nilesat Last edited by canofan; 24-01-2008 at 10:24 AM | ||
| | #36 | ||
| ASBO Club Member - Persona non grata Join Date: 10-09-2007 Location: Tunisia, Prince Of Persia
My System: None | I read that in the UK it's better to live in an apartment 5 floors up or more because then you are allowed to have up to 120cm dish on your balcony. Is that true? | ||
| | #37 | ||
My System: DB7000S HDD USB2GB; FTE MAX S102; 2CM120+ 2Norsat7706A on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E | As I live in Belgium, at the moment, so I have not been informed of the trend. In Belgium, I battled 3 years to be allowed access to the roof and that at the condition that I supply 19.2E and 13E to whoever requires it in the building. My balcony is badly oriented. But you cannot be forbidden a less than 80cm dish, as at this size and below it is reputed invisible. | ||
| | #38 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No it isn't true, the rules for dishes on apartment blocks are in the sticky thread at the top of this section, but dishes on apartment blocks are also normally controlled by the management company or housing association in the first instance, the planning guidelines cover the entire block.
__________________ | |||
| | #39 | |||
As I have learned, from Channel Hopper, that the dual feeds were designed for receive only. The specs for the Andrew 611-6062-10 feedhorn call for use in the 11.7 to 12.2 ghz. So it was meant for separate Vertical Horizontal standard LNB's in the 11.7 to 12.2 ghz band. Last edited by canofan; 25-01-2008 at 02:28 PM | |||
| | #40 | |||
| Guest
Posts: n/a
| There is two versions of the 6062-10 a single flange version and a twin flange we only use the twin for RX-TX vsat. The single is just the same as the twin but the twin comes with the twin waveguide but with the single you just bold the lnb direct to the feed like you do at the moment,
| | #41 | |||
The one with a single flange is the 661-6060-10. The 2 in 6062-10 refer to the twin. What if I used the Twin flanged for two Norsats. Surely this is an unorthodox way of using it. But I do not see, technically, any contraindication especially that both waveguides have an identical VSWR of 1.3:1. | |||
| | #42 | ||
| Member Join Date: 21-11-2006 Location: Northwest
My System: Nokia 9600S (NDT tuner) linked via RS232 to Echostar LT8700. Motorized 1.2m Echostar offset dish on polar mount with 12" 36V jack. Combined Ku feedhorn polarotor with Calamp WR75 0.8dBN quadband LNB. Skystar2 v2.3 via splitter. | From the illustrations those twin flange VSAT feedhorn assemblies look to me like a bog standard C120 feedhorn, to which a standard OMT has been bolted on the back. If not what does the extra wave component do exactly that is different from the standard sort of OMT, as has been used with two WR75 LNB, one each for H and V, for receive-only for many years past? | ||
| | #43 | |||
| Member Join Date: 26-07-2008 Location: LATIN AMERICA
My System: 4 SAT AND 2 STB |
| | #44 | |||
My System: 4 SAT AND 2 STB | thank you... | |||
| | #45 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master dish @1west, vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | cant you contact andrew or now as they are know asc signal and order a set of feed arms for the dish ? | ||
| | #46 | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello! now andrew is out of bisness,when i call the the owner,they are not very helpfull,,maybe when you have a conpany you have more luck! today,its nearly imposible to find old channel master stuff,out of production we have nothing thats the answer ,in austria the satelite antena section,is completly colsed... | ||
| | #47 | |||
because i lost my CM 2.4 mts main and side arms lnb support and i want to buil them, but i need the exact measure of each one of them. thank you... | |||
| | #48 | |||
I recommend that you try find the arms or replace them with the original CM/Andrew/ASCsignal. Unless you can borrow them from somebody to build an exact replica and I really mean exact. | |||
| | #49 | ||
My System: 4 SAT AND 2 STB | is there a CM 2.4 mts specifications document around the internet that i can download? or anyone of you fellas would be kind enough to go outside and take measurement of the arms ( three of them) and give me that info please...? thank you very much... | ||
