LNB Position & Angle Setup Problem | |
| Regular Member Join Date: 07-08-2007 Location: South Oxfordshire, UK
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable |
Before mounting my fixed-dish with multi-LNB on the wall, I decided it would probably be a good idea to set the LNB mountings to their correct positions first. The problem is that unless my calculations are wrong, I seem to have an issue with not being able to get one of the LNB holders close enough for the required angle alignment... (click for full size picture) LNBHolderPositions.jpg The length of the LNB arm from the dish to the centre of the LNB holder in a straight line (green line) is 470mm. The LNB on the end of this will be pointing at 19E. The LNB on the left-hand side (blue line) will be for 28.2E so the angle between the green and blue lines at "A" needs to be 9.2°. This means that the distance of the LNB holder from the central holder (dimension "B") needs to be 76.1mm. This is no problem and I have set that LNB holder in the correct position successfully. The LNB on the right-hand side (red line) will be for 13E so the angle between the green and red lines at "A" needs to be 6°. This means that the distance of the LNB holder from the central holder (dimension "C") needs to be 49.4mm. This is where the problem lies as the closest I physically can get that LNB holder to the central one on the arm is 60mm. This is obviously going to mean the angle of that LNB to the centre of the dish will be incorrect (7.28°). To calculate the correct positions of the LNB holders I used an online triangle calculator. Am I doing something wrong here or is there some way around my problem that I'm not aware of? The dish is a Raven Gemini 70cm dish with the standard Raven east/west LNB holders attached. I'm sure there must be other people running a 13E / 19E / 28.2E setup with the same dish so I would be interested to know how to do it. Any help / advice on what I can do to resolve this problem would be much appreciated. Gary Last edited by garym71; 24-10-2007 at 12:38 AM. Reason: Typos | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I normally only use the Eastern sats offset, using hotbird in the centre, you may not be spot on with central focus on the 19E LNB, but it will work. ![]() I tend to adjust the offset LNBs using a meter.
__________________ | |||
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable | I see what you're saying but I'm still not entirely sure how that would work ![]() If I point the centre LNB (directly on the end of the arm) to Hotbird 13E then on the eastern offset bracket (the left-hand one), the next LNB along for Astra 19E will still need to be 49.4mm from the centre arm LNB holder (to the immediate left) which is simply not possible due to the width of the holders. Am I missing something here with how the holder position locations should actually be calculated & set or is the real solution to start modifying the LNB holders? (i.e. try to slim them down by filing siome of the side off) | ||
| Section Leader Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Bros is there any kind of software which can help our bro garym, To hold multi lnb. calculation.
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You don't need software, I have set up many of these dishes with Eastern sats offset bracket, it works perfectly. The bracket needs to be bent inward slightly and upwards, the Astra 19.2 LNB will be just touching the Hotbird LNB, see example below.
| | #6 | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide |
__________________ Oldgeezer | |||
| | #7 | ||
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable | OK, having taken in the replies and after doing some further research, I think I now understand things a bit better ![]() Using dishpointer I've found out the that my location requires the following azimuth's...
As Rolf has already stated, I might not be able to get dead on the centre of the dish from the 19.2E LNB due to the close proximity of the 2 LNB feedhorns but I can set the calculated LNB holder positions before I mount the dish and then play around slightly with minor adjustments to get the best signal once the dish is actually on the wall. I'm sure I'll think of some more questions again before that though ![]() Thanks guys | ||
