problem alinging dish arabsat | |
| bog standard Join Date: 02-07-2007 Location: norwich
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2. |
hi all be trying to align a 95 cm dish to arabsat 26 degrees.but did not have much luck it seems i can get a good vertical signal or a good horizontal but not both at once.there seem to be a 2 to 3 degree difference between the h and v polarizations.lyngsat recommend a 90 to 120 cm which this dish falls in to.the chap says his freinds use a 1 meter dish with no problems but im not so sure.this is the first time i have tried to find this satellite so i have nothing to cross reference with.so if there is a member with any experience of this sat please reply thanks in advance.the paticular channels that he said he had before it started to hang off the wall was mbc which has its own footprint. Last edited by moosegoose; 30-10-2007 at 07:55 PM. | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If your dish is as you say in your profile, it really isn't big enough, if you can move a couple of degrees, then you are not on the same satellite.
__________________ | |||
| Section Leader Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | 95 i thing 90...! Profile dosent sounds that.
| | #5 | ||
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2. | sorry mate did not get the last post.i have done quite a bit of research now and come to the conclusion if i can get the mbc foot print the others will be a easy.it is not clear what size dish is necessary as there are so many conflicting posts.ie i can use any dish from 90 cm to 130 cm and it will work or it wont.at the moment it will not work with a 95 cm on a still clear day.i also read a lot about 28 degrees washing the signal out if this is true a larger dish will not work as it will just pick up more of 28 degrees. | ||
| | #6 | ||
| SkysNotTheLimit Join Date: 30-09-2007 Location: Spain / North Kent
My System: Octagon 318, 1.1m Triax, dish and Orbital Disecq Motor,plus all other stuff |
Not true. Bigger dishes are harder to align for quality. You need a good meter to align at least a 1m Triaxon Aabsat ( name has changed) In Kent a 90cm works. SKEW lnb perfectly, that is the key. A strong signal but REDUCE THE NOISE. | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The bigger the dish, the narrower the dish focus, so it will be less affected by an adjacent satellite.
| | #8 | ||
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2. | ok thanks rolfw i think i will try a triax 110 cm as your last post has cleared some of my concerns. i think the combined effect of more signal and a narrow focal point should work in all but rainy conditions. many thanks. | ||
| | #10 | |||
| Regular Member Join Date: 05-10-2005 Location: UK.
My System: technomate 1500 strong 4375 pace digi box triax 1.1, triax 88cm |
yes i think a 110 cm should definately do it, it really is a awkward one to get, i myself use a 88cm from the north east, my dish is in the garden and i take a tv monitor and put it right next to it that definately helps. | |||
