LNB Short, how do i fix error ?Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Supporting Advertiser Join Date: 22-10-2007 Location: Colchester in Essex
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB. |
Disconnected the LNB cable into my echolink box last night to reconnect up another box to my dish, then i forgot to turn off the box before i reconnected it back up again, Im now getting the "LNB SHORT" message on the screen which i have never come across before. Whats the solution to fixing this, where do i start ie Receiver, Cable, LNB ? Just to add mysetup is a monblock LNB astra/hotbird thanks in advance. | ||
| | #2 | |||
| Regular Member Join Date: 05-10-2005 Location: UK.
My System: technomate 1500 strong 4375 pace digi box triax 1.1, triax 88cm |
i once had a similar problem it might not be the case but i ended up having to get a new power supply put in, mind you can always try putting another lnb on the end | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Check the connectors, particularly at the receiver end, that is probably the source of the short. | ||
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB. | I'll get my meter out later and test the LNB and see if its that, i did read elsewhere that the box may need a factory reset, didnt want to do that yet cause i'll loose all my channels that ive spent hrs setting up the way i like. I'll start with the LNB and go from there..... | ||
| | #5 | ||
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB. | | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Most times a power off at the mains will reset the short protection in a receiver. Always check the parts you have changed first, the connector at the receiver end is the prime suspect. | ||
| | #7 | ||
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB. | It turned out to be one of my connecters was the problem. I used my sat meter and was able to locate which connecter it was within a few minutes and fix it. Nice little exercise for me to do, im sure that will come in useful in the future ;-) Thanks all. | ||
| | #8 | |||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 | deep joy dave | |||
| | #9 | ||
| | #10 | ||
| Member Join Date: 22-09-2008 Location: Rovigo, Italy
My System: Satellite Installer | Hi Cdtronix, I had that similar problem affecting my two clarke tech receivers....Please do help me and explain the way to handle the problem. I will be glad to see that work for me. Thanks in advance..or you can still reach me with my email address below...removed admin | ||
| error, fix, lnb, short |
