Digi Globe Reception. | |
| Member Join Date: 31-10-2007 Location: Scotland
My System: Not Yet. |
I'm thinking about buying a Digi Globe Dish; but, I live in Scotland. The Gain on this device is 33dB, with a diameter of approx 400mm (40cm). Will I get a decent reception? I was hoping to receive anything on Astra and/or Eutelsat. Last edited by Nell; 02-11-2007 at 12:24 PM | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Which satellite are you wishing to receive Nell?
__________________ | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I would think it should be OK for that satellite, but you may get some dropout in bad weather.
| The Following User Says Thank You to rolfw For This Useful Post: | Nell (16-11-2007) |
