LNB Vertical Polarisation Rotation Position
Thread Tools Display Modes
Old 03-11-2007   #1
garym71's Avatar
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable
I have now finally got all the kit I need to set up my fixed-dish multi-LNB system
However, after getting the LNBs which are all MTI 0.2db ones, I noticed that the 2 single output LNBs each have a position marker on to indicate which rotation position the LNB should be set to for vertical polarisation (a triangle with a few markings either side). This is no problem as I will set this initially to the top and then adjust the skew as required.
However, the quad output LNB made by the same manufacturer has no such marking on Am I to assume that the vertical polarisation for this LNB is with the long vertical body part of the LNB (with the 4 F-connectors on the bottom) positioned straight up and down vertically?
Thanks,
Gary
garym71 is offline   Reply With Quote
Old 03-11-2007   #2
Amo Amas Amant Admin
Topper's Avatar
well
Thanks,
Gary
I think you are safe to assume that
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 03-11-2007   #3
garym71's Avatar
OK great. I'll start with that and see what happens
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
