Vertical versus Horisontal Polarisation | |
| Regular Member Join Date: 07-08-2007 Location: South Oxfordshire, UK
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable |
The single LNBs I have for my new setup (MTI 0.2db ones) have the F-Connector coming out at a 45 degree angle when the skew is set to zero for the vertical polarisation (see attachement below). With the additional negative skew required to line up to 28.2E, the connector/cable is coming out almost horizontally from the end of the LNB (between the 8 and 9 o'clock positions). If at all possible, my preference would actually be to have the cable coming out at more of a vertical position purely for neatness than anything else. I know nothing about Vertical versus Horizontal polarisation but my Sky box is currently set up for Vertical polarisation. If I was to set the polarisation to Horizontal then would that mean I could turn the LNB 90 degrees clockwise to recieve the incoming signal on it's horisontal axis (with the cable coming out more vertically) or have I completely misunderstood what Vertical and Horizontal polarisation actually is? Last edited by garym71; 06-11-2007 at 10:31 PM. Reason: Typo in the title | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Not really sure what the question is.... Your Sky box is receiving both horizontal and vertical channels of that I can assure you unless it is faulty. Provided you insulate the F-connector correctly to stop the ingress of water using either the manufactured sleeve (if supplied) or self amalgamating tape then. I believe the convention is to have the connector below horizontal to allow water to drain away from the connector down the cable as opposed to down the threads and connector
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You will be making a lot of work for yourself by trying to muck about with the polarities, easier to swap the LNBs out for a couple of Invertos, they do not have the skewed outlet. ![]()
__________________ | |||
| | #4 | |||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | I still fail to see why a manufacturer would produce an lnb with such an impractical angle of output for the F-connector
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | |||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I thought it was strange when I first installed one, but actually it woks quite well on some LNB holders, the LNB itself is not one of MTI's best though, I have had to return a couple of them in the recent past.
| | #6 | ||
My System: Pace TDS470N Sky+ Receiver, Technomate TM-5400CI+ FTA Receiver, Raven Gemini 70cm Mesh Dish with East & West offset LNB brackets, 2 x MTI 0.2db Universal LNBs, MTI 0.2db Universal Quad Output LNB, Eurostar 4x1 DiSEqC Switch, Webro WF100 Cable | I guess I completely misunderstood what Vertical / Horizontal polarisation meant then ![]() I bought the MTI's for 2 reasons: because they were low noise at 0.2db and because they were dark in colour so as to be less obtrusive against the black dish. Until I got them I wasn't actually aware that the connector came out at an angle and only realised this after they were delivered. I think I'll just live with them for now and maybe replace them at a later date if I decide it really bothers me that much. If the skew was positive then they would work much better but all the skews I need to use are all negative. I see the Inverto's have a black body so these would probably be a suitable alternative if I decide to change the MTI's. Rolf...when you say the MTI's aren't the best quality, what issues did you experience with them? I only paid £9 each for the singles so maybe I made a mistake buying some cheapo ones which aren't actually that good ![]() | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I've had three of that type fail (out of not very many), plus several quad versions and one Quattro, fail on high band, so I am not a lover of them any more.
