LNB Setup | |
| Regular Member Join Date: 14-11-2006 Location: Athens-Greece
My System: CM 3.0m @ 28.2 w PACE |
Hi, anyone know what the "LNB Low Band LO Frequency (Ghz)" and "High Band LO Frequency (Ghz)" mean in the LNB setup menu of a digibox ? | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | It's the local oscillator frequencies of the LNB. For a Universal LNB (by far the most common), the low band frequency is 9.750 GHz High band frequency - 10.600 GHz Llew | ||
| | #3 | |||
My System: CM 3.0m @ 28.2 w PACE | and got all sorts of results. At one point signal and quality maxed out! and then again I had to reboot the digibox... Is there any point in changing them ? Could you for instance "focus" the LNB on specific freqs this way ? or perhaps what are they there for ( in the installers menu ) ? | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There is nothing to be gained in changing those settings, unless by a few points to match an offset in LNB LO frequency, or if you are not using a universal LNB.
__________________ | |||
