Optus D1 | |
| Member Join Date: 30-07-2007 Location: New Zealand
My System: DIY installer |
I have a problem receiving free channels from Optus D1. In, New Zealand. Want to receive Imparja and other new Free view from Australia. I got the frq and S/R from Lyngsat, but did not work. I am getting other channels without any problem, Those new free channels not getting from auto scan. What are the freq, S/R, Vpid, APid and other codes need to be enter manualy to get this cahnnel. Your help would be highly appreciated. many thanks. | ||
| | #2 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue |
__________________ | |||
My System: DIY installer | According to the table I used followings. Freq 12643 vertical S/R 6874 Vpid 1024 Apid 1025. is this right. Bu I am not getting anything from the above code. any idea. | ||
My System: DIY installer | normaly what i am doing is just do the blind scan (or auto scan) then receiver scan certain range of fequiencies. Could you plesae give me fw examples about the codes of TV3, Maori, TVNZ6 etc. Then I can compare the codes with other channels Thank you | ||
| | #5 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | All the frequency info you need is on the link I gave you in the previous post
| | #6 | ||
My System: DIY installer | Thank you for the reply, I found all the frequiencies from the chart given by you. But i am not getting the channel. Do you have any idea ( where to check) why I am not getting. My other question, is it possible to connect one dish to two seperate satellite receivers. ( two different brand receivers). I can use splitter to split the signal comming from dish to feed two receivers. But receivers are feeding the power (0-18V) to lNB. There will be conflict between two power source coming from the receiver. Much appreciated your comments. | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Use a twin LNB.
| | #8 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. |
Alternatively, if your receiver supports it you can use the IF 'loop through' One of your receivers may have an extra f-connector on it, labelled 'IF Out' or similar, this can be conected to the input of the 2nd receiver. The 1st receiver has to be switched off however, for the 2nd one to work. | |||
| | #9 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | mpj111, you dont have a dect telephone by any chance do you? If so turn it off (and the base unit) and see if you can pick up the channels on that frequency.
| | #11 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | DECT are digital cordless phones. They are notorious for causing severe interference to tv channels carried via satellite on frequencies around 12480 MHz here in Europe. In fact in Germany its so bad several of the public service channels had to be moved off 12480MHz on 19E!
| | #12 | ||
| Member Join Date: 01-01-2000 Location: Downunder
My System: 3.6M Ku Band Orbitron, 3.0M Orbitron C band. 1.2M Ku offset, 1.0M Ku Offset, 90Cm/Moteck Ku, 65Cm Ku Offset, Nokia Dbox 9500s, Nokia Dbox2, Dreambox 7020s, Dreambox Dm500s, Innovia 3088, UEC 660, Pace IQ PVR SkyBox. | Hi MPJ111 Imparja/NiTv via D1 are there, but using Hidden PIDS. By editing the following PIDS into your configuration or Search you will ba able to see these services. Imparja : VPID = 1024 APID = 1025 PCR = 1024 NITV : VPID = 1040 APID = 1041 PCR = 1040 Give those a try and you'll be away.. Cheers:
__________________ pc:: | ||
